i really need internet on my pc and i can't connect my pc on an Lan port so now i have the question which plan stick/Pci card should i get which one ist the best wehre i also could game on ...
This one:
ASUS 802.11ac Dualband Wireless-AC1900 PCI-E-Adapter
or this:
AVM FRITZ!WLAN USB Stick AC 430
i really need a fast answer
https://linustechtips.com/topic/251053-help-i-need-internet/
Unless you're gamestreaming over your router the second option has plenty of bandwidth to game on.
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
https://linustechtips.com/topic/251053-help-i-need-internet/#findComment-3441748
