Power consumption question
Go to solution Solved by mvitkun,
gtx 770 -214 watts max
i5 3570 -77watts max
water 2.0 -27 watts max
SSD -3 watts max
HDD -10 watts max
water 2.0 fans -12 watts (for both)
1x140mm fan(.22A @12V,assuming the spec is the same as AP121) -3 watts
~346 watts max,assuming you don't have anything else.
this is not including any case fans other than the one included with the FT03 mini and the water 2.0 fans.
since the power supply is pretty damn good quality I'd say go for it you should be fine.
but I would highly discourage any overclocking.
Hi guys, i'm planing on moving my mITX pc to a Silverstone FT03B-MINI case and these are the parts that I am planing to put in there.
GTX 770 Graphics Card (230w)
Seagate Barracuda ST3000DM001 3TB 7200 RPM 64MB
GIGABYTE GA-Z77N-WIFI INTEL Z77 PCIe mITX
Intel Core i5-3570 Ivy Bridge 3.4GHz
Kingston HyperX Blu 8GB (2 x 4GB)DDR3 1600
Corsair SSD 60GB Sata3 Force Series GT
Thermaltake WaterCooling Water2.0 Performer
So my question is, will the power supply for this case, the Silverstone SFX Series 450W 12V 80PLUS Gold, will be up to the task of powering up this computer?, my main concern comes from the graphics card, since I know it will be the main power eater in the system.
I don't plan on overclocking, since I think i'm at the edge if not over what this power supply can deliver.
Any comment, thought, or help is appreciated. (^_^)
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/25081-power-consumption-question/
500w will work but you would be safe at 650w
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-317843
Yeah like what everyone else said, 500w would be enough to power it, 650w for the headroom.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-317862
SSD -3 watts max
HDD -10 watts max
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-317926
It's fine, as mvitkun said you won't be going anywhere near 450w with a system like that. This is especially since power estimations show maximum values at best, essentially the highest value that could occur when running stress-testing programs like Prime95 and Furkmark simultaneously. If you see techpowerup's review of the GTX770 for example, during gaming load the average power consumption of the card was actually 160w.
As a result, power consumption during gaming load would probably average around 300w, slightly higher whilst rendering and such. Since the unit is of high-quality anyways, there's really no problems with running it at that kind of a load for extended periods of time.
On a side-note, why are you getting an AIO CPU cooler if you aren't overclocking anyways? Sticking with the stock unit of getting a cheap air cooler (if you wish for silence) would easily suffice for a stock Ivy i5.
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-318567
SSD -3 watts max
HDD -10 watts max
Yes, I am not thinking of overclocking, since I knew the power limit of the PSU was about to be reached, (on my estimates); Also, I won't be using the coolers fans, since according to linus' video about how to build in this case I only need the radiator and its pump, the only fans on the case, will be the one that comes with the case, the PSU, and GPU.
And  thank you for your very complete answer, I'll build this pc, if I am not lucky and can't run that graphics card I have a 660ti in reserve :D (I really hope I am not forced to use it though D: )
I have already stress tested the CPU, since I have my pc on another mITX case, I don't have the 770 but I can always stress test it on another computer ^^, about the AIO cooler, I wanted something more silent, that's why I changed it
I am thinking about changing the HDD for a green one , it will help with lowering overall consumption, will it impact too much gaming loads and stuff?
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-318785
It will lower power consumption, but you will notice reduced random I/O performance, and a very small sequential performance reduction. Game loads will be a little slower but not noticeably.
I do not feel obliged to believe that the same God who has endowed us with sense, reason and intellect has intended us to forgo their use, and by some other means to give us knowledge which we can attain by them. - Galileo Galilei
Build Logs: Tophat (in progress), DNAF | Useful Links: How To: Choosing Your Storage Devices and Configuration, Case Study: RAID Tolerance to Failure, Reducing Single Points of Failure in Redundant Storage , Why Choose an SSD?, ZFS From A to Z (Eric1024), Advanced RAID: Survival Rates, Flashing LSI RAID Cards (alpenwasser), SAN and Storage Networking
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-319017
Thank you :D, I normally only surf the internet and play games, so i think I should be ok.
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-321672
TDP is not power consumption lol.check wiki.look at this for ex:
-total system use @ stress test 48 W at wall. only the i3 2100 TDP is 65W lol.
 gtx 770 max is 180W
and the psu is more than fine for it here a video with Linus using it with i5 K ,gtx 670 with OC,STRESS test and everything
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-322997
 gtx 770 max is 180W
http://www.guru3d.com/articles_pages/core_i5_3570k_review,10.html
power consumption for the i5 3570K system was 85 watts idle and 160 watts load,with the graphics card in it.
a way to estimate the power consumption of the cpu is do prime 95 load-idle = cpu only
because during idle cpu will be a very small part of the power consumption.
160-85=75 watts.so is it wrong to use the 77 watt tdp given by intel,I would say no in this scenario.
as to the 180 watt power consumption for the GTX 770 I used the MAX load consumption,as in furmark. because while it's not a realistic  representation it sets the bar.
meaning,if it can run stably under furmark + prime95 simultaneously,temp and power consumption wise,you'll be fine in real world scenarios.
https://linustechtips.com/topic/25081-power-consumption-question/#findComment-329243
