Hey guys. I come to you today with the problem of my GTX 770 underperforming like mad. It has been like this for the past few weeks now. Playing battlefield 4 at high settings I get 35-40 fps with dips into the 20s. In CS:GO I get around 80FPS with dips into the 50s. In cinebench openGL test I get 67FPS. My temperature is always around 60c and my driver version is 344.65. I'm scared I need your help. please.
EDIT: This all started after I cleared my CMOS so that may have been causing it.
wow, thats a lot of bees!
https://linustechtips.com/topic/249709-underperforming-gtx-770/
What are the clocks of both CPU and GPU?
woot 6000th post.
https://linustechtips.com/topic/249709-underperforming-gtx-770/#findComment-3424367
Maybe its getting to hot and throttling
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/249709-underperforming-gtx-770/#findComment-3424390
turn down your CPU overclock? a semi unstable overclock can really kill your GPU framerate.
woot 6000th post.
I forgot to change my signature, I cleared my CMOS after some weird stuff happened so I am back at stock as of now
https://linustechtips.com/topic/249709-underperforming-gtx-770/#findComment-3424413
