So what custom rom is best ui for G2
(I Use CM 11 On my G2 Right Now )
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/249295-custom-rom-for-g2/
any recommendation ?
https://linustechtips.com/topic/249295-custom-rom-for-g2/#findComment-3418824
On my G2 I'm currently using AOKP ROM. SlimKat is another good one.
i don't think slimkat will have update to lollipop without install new rom
i want rom like cyanogen because it have updater what makes you don't need to factory reset your phone to update
https://linustechtips.com/topic/249295-custom-rom-for-g2/#findComment-3419186
guess i will stick on Cyanogen till someone release lollipop rom for G2
https://linustechtips.com/topic/249295-custom-rom-for-g2/#findComment-3419189
that one. maybe try a costum kernel from xda for some improvements. keep cm11 and watch out for lollipop it shouldnt take long
yeah i think i will stick on Cyanogenmod since i just switch from CloudyG3 Rom cause i don't think they will update that rom to lollipop
https://linustechtips.com/topic/249295-custom-rom-for-g2/#findComment-3419200
I'm using Cloudy. It's much closer to the stock G3 ROM than most and is probably the most popular G2 ROM.
Oneplus 6 | Sony 55" X900F . Lenovo Y540 17" 144Hz RTX 2060 . i7 9750h.
Audio-GD DAC-19MK3 > Schiit Lyr 2 + > FOSTEX TH900 . Sony XBA-Z5
https://linustechtips.com/topic/249295-custom-rom-for-g2/#findComment-3424272
