cm 690 ii advanced modding
Go to solution Solved by ericlee30,
Yes there is 4 screws at the bottom of the case, just take those out and the bottom half of the tray comes out. For the top 3 drive bays that will be left, you would have to drill the rivets out in order to remove them but to be honest, when you remove the bottom drive cage, there is a ton of room for air flow. I never removed the top drive cage as I felt there was no reason to.
i want to take out the hdd cages for airflow improvement, does anybody have done this before? and what can i do with my hdd and 2 ssd's to put them safe and secure?
I7 3930K @4.4 GHz  /  Asus rampage 4 formula  / 4x 8gb kingston hyperx blue low profile / gtx 980  / 2x ssd 500gb samsung 840 / 500gb 840evo ssd   /  500 GB WD blue /  windows 7 ultimate
my build: http://linustechtips.com/main/topic/133477-750d-finished/
https://linustechtips.com/topic/24924-cm-690-ii-advanced-modding/
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/24924-cm-690-ii-advanced-modding/#findComment-315705
ok,, that should be easy enough thanks :) don't want to take any chances on braking the damn thing :p
https://linustechtips.com/topic/24924-cm-690-ii-advanced-modding/#findComment-315715
ok,, that should be easy enough thanks :) don't want to take any chances on braking the damn thing :P
Your welcome :) also if you want to do something with the SSD's besides putting them in the top 3 Drive storage cage, you could mount them on the right side panel after you remove the bottom drive cage. I don't know if you like that idea but it's a suggestion :)
https://linustechtips.com/topic/24924-cm-690-ii-advanced-modding/#findComment-315728
and how would i do that? i usually put things in the easy way :rolleyes:
https://linustechtips.com/topic/24924-cm-690-ii-advanced-modding/#findComment-315786
Ok, I'm not at home right now, I'm on Vacation, so the Pic down below is not my own pc and I do not clam that it is. It is a pic i found through Google pics :)
You can use 3M clear double sided tape Model #4010 or you can get velcro strips  to get the SSD's to mount to the side of the case, doing it this way will not interfere with air flow and will look pretty cool as well.
https://linustechtips.com/topic/24924-cm-690-ii-advanced-modding/#findComment-316091
ok thnx; will give it a shot tomorrow
https://linustechtips.com/topic/24924-cm-690-ii-advanced-modding/#findComment-316146
