Hey guys, i want to put together a new rig and need some advice.
This will be primarily used for gaming/photo editing/video editing.
This is going to be a  Black and Green build.
I am getting the Razer H440 so i want it all to match.
Also want this to be intel.
Able to support 2+ monitors
Able to run any new game in 60fps and 1080
Unsure about the components that i want to put into it. I want to do at least a liquid cooled CPU so one of that all in one NZXT or Corsair units would be required.
I also already have 2 samsung 256gig ssd's. So no need for another.
I will want to have a 1tb harddrive installed but that should be all i need, currently write to an external 5tb so that it can travel with me.
I want this to be upgradable in the future if i want.
Budget will be around 1000-1500 for the rest of the components ignore the things i already have.
Would also like some monitor suggestions but dont include those in the budget, will have a separate budget for them.
I appreciate any help you guys can give! as well as giving some insight into why you picked things so that i can start to help the community and not need help the next time i build something :D
Thanks
Ron
ALSO WOOOO FOR MY FIRST FORUM POST
https://linustechtips.com/topic/248885-new-build-help/
Please tell us what you do have.. so that way we don't have to worry about placing them into partpicker.
I have 2 Samsung 840 Pro Series 256GB 2.5" solid state Drives
NZXT H440 ATX Mid Tower Case.
This http://pcpartpicker.com/p/mdvN23 and an VG248QE monitor from ASUS is the monitor i will keep on recommending.
Power supply? Ram? CPU cooler? 1tb HD? OS?
But thanks for posting anyways. i will look into that monitor
https://linustechtips.com/topic/248885-new-build-help/#findComment-3413627
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($309.99 @ Newegg)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($129.99 @ SuperBiiz)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ Amazon)
Memory: Mushkin Blackline 16GB (2 x 8GB) DDR3-1600 Memory  ($151.99 @ Newegg)
Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card  ($379.99 @ Newegg)
Case: NZXT H440 Designed by Razer™ ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: XFX ProSeries 750W 80+ Silver Certified Semi-Modular ATX Power Supply  ($77.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($90.26 @ OutletPC)
Monitor: Dell U2414H 60Hz 23.8" Monitor  ($0.00)
Total: $1330.19
Generated by PCPartPicker 2014-11-11 16:06 EST-0500
https://linustechtips.com/topic/248885-new-build-help/#findComment-3413826
Total: $1330.19
I like the build, anyone else have any more suggestions?
i was hoping that i could get some insight into why everyone is picking these things since people are picking different components.
https://linustechtips.com/topic/248885-new-build-help/#findComment-3414207
He has chosen a decently powerful CPU because you you say you photo edit/video edit therefore a good cpu is definitely required. The 16gb of ram would be to make that photo/video editing process as smooth as possible. The GTX 970 is a perfect card for gaming at this price point and resolution of gaming and the PSU allows you for future expandability.
But personally I would choose my choice from above, same cpu but better graphics card and psu with a nice red motherboard to match your colour scheme
https://linustechtips.com/topic/248885-new-build-help/#findComment-3414319
How does a red graphics card match a Black/Green color scheme?
Thats why i didnt comment on yours, it didnt seem like you had read the requirement for the green and black scheme
https://linustechtips.com/topic/248885-new-build-help/#findComment-3414336
ohh shit for some reason i read red and green uhh just get a black mobo and black ram and you're good on mine
https://linustechtips.com/topic/248885-new-build-help/#findComment-3414419
