How does one power supply?
Go to solution Solved by Bogica,
Get a 600W PSU, just to be on the safe side and leave room for upgrading. :)
So I'm building my first custom computer and such, and I used a bunch of those online psu calculators, and they all gave different amounts, ranging from 383 watts to 585 watts. I need help!!! The specs will be:
Intel i5 4670K
ASRock Fatal1ty Killer LGA 1150 Motherboard
In Win GT1 Black SECC case
8 gigs of Corsair Vengeance 1600 RAM
1 TB Seagate Barracuda ST1000DM003 HDD
128 gig Samsung 840 Pro SSD
2 Corsair AF Series quiet LED red 120mm fans
Gigabyte Windforce 4 gig GTX 970 graphics card
(I'm planning on OCing)
Edit - on Nvidia's website, it says the GTX 970 needs at least a 500 watt psu
Sally: l Intel i5 4690k | | Corsair H55 | | Zalman z12 plus | | Hitachi 2TB HDD | | Samsung 840 Pro 128 GB | | ASRock Fatal1ty z97 Killer | | Corsair Vengeance 16 GB | | EVGA SuperNova 750 watt | | MSI 390 | | Windows 10|
https://linustechtips.com/topic/248694-how-does-one-power-supply/
Id say that system draws less than 400W. But since theres small price differences between 400 and 600W psus id suggest getting a decent 600W one.
Core i7 4820K  |  NH-D14 | Rampage IV Extreme | Asus R9 280X DC2T | 8GB G.Skill TridentX | 120GB Samsung 840 | NZXT H440  |  Be quiet! Dark Power Pro 10 650W
Personally, just go with an 850 watt. They are not that expensive (about 100$ on Newegg and Amazon) and it leaves you pleanty of room for upgrading. you will also never need to worry about running out of power, so if you ever want to throw another GPU in a some point, then you are good to go!
You won't really use more than 400w, I'd go with something around 600w.
That psu doesn't exist. The G2 models start from 750W.
Might've been thinking of a different EVGA PSU, I stand by my point of getting a good 600w PSU though.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
