Hello guys, I'm planing a build log here, currently is in funding progress. Some tragic events happened that I cant build a RIG recently, I most likely will build it after my major examination and if I can get the funds. These are my part list:
RE-EDITED on 14 Jan 2014:
Intel i5-4670k processor
Gigabyte Z87X UD3H Motherboard
Sapphire R9 280X Vapor-X
Kingston Hyper X RAM 4GB x 2
Samsung 840 Evo / Kingston SSDnow V300 / ADATA XPG SP900 / Plextor M5S 120GB
Western Digital Black RE4 1TB (if possible)
Seasonic G series 550W PSU
CM Hyper 212X
DeepCool Tesseract ATX Case
Extras:
Scythe Gentle Typhoon 120mm / Silverstone AP123 x 2
Peripherals:
Samsung 23 inch IPS monitor S23C350HS
CM Storm Quickfire Stealth Red Switch
Microsoft Intellimouse Explorer 3.0
IT IS CONFIRMED!!! COMING SOON IN MARCH! SUGGESTIONS ARE WELCOMED!
https://linustechtips.com/topic/24855-project-razor-windconfirmed/
Use of build/intended budget?
What are you going to use this for? If it includes recording/rendering I recommend an i7 and 16GB of RAM
This is a gaming RIG, I have no specific budget, just trying to keep costs low as I will be getting a monitor also.
So are you trying to keep costs low or do you not have a budget?
A custom water loop isn't the cheapest way to go.
I don't think you can do a water-cooled build for 1600$ without compromising performance/features...with the money you save by not buying custom water cooling parts you can get 16GB of RAM, an i7, etc...which do affect performance
Yes, you can overclock the i5 to get similar speeds as the i7, but games in the future will benefit from aditional cores/threads and more RAM.
Well, Just trying to keep everything within $1600
Considering your budget, your build will cost to much.
This is what I would/(you could) do instead: http://pcpartpicker.com/p/155j8
I dun think I can afford an i7 as an i5 in Singapore is almost the same price as an i7 in US or Canada. I'm going for 16GB of RAM also.
  • 4 months later...
An update on the part lists:
Intel i5-3570k (Haswell is too expensive for that performance)
Asus Z77 V-Pro
G-Skills Ripjaws X 2x8GB RAM
Samsung 840 Pro 256GB
Seasonic G 550W
NZXT Kraken X40
NZXT Phantom 530
Peripherals:
Deck Hassium Mechanical Keyboard
Logitech G602
Asus Z77 V-Pro
Seasonic G 550W
NZXT Kraken X40
NZXT Phantom 530
Peripherals:
Logitech G602
Haswell has better mobos. Just get the 4670k and the cheapest z87 mobo.
The 840 Pro will perform noticeably the same as the normal 840. The difference in speeds are negligible there and you can save money with the normal 840.
Why Kraken x40? No mass storage?
  • 2 months later...
After working for 2 months, I have almost enough money to build the whole PC now. There are changes to the parts.
GSkill Ripjaws -> Kingston Hyper X RAM
I have some good deals for it
Samsung 840 Pro -> Samsung 840 Evo / Kingston SSDnow V300 / ADATA XPG SP900 / Plextor M5S 120GB
I can get the listed SSDs at a good price, still deciding on which to go though...
I can import a legit one from China and it is cheaper and can be RMA-ed locally in my country.
DeepCool Tesseract
It is the new case by DeepCool. Although the case has no window, but the fan grill on the side panel is big enough to be one. It is really cheap and has all the tool less features as well. Will be swapping out the front fan with either 2 Gentle Typhoons or AP123s as a guy in another forum shows that thermal performance improves if the fans are swapped.
http://www.deepcoolglobal.com/Product/TESSERACT_H/Design/
