HELP audio issue... searched everywhere.
Hello all, this may not be the best forum for this, but there wasn't a trouble shooting one on this site...so here we go, please help
When i play media on my computer via youtube and other sources there is this jittery, buzzy sound and it hesitates. Not like it's buffering, it's def a PC issue. It plays, just just makes like a crackle sound, buzz, jutter every few seconds. It is driving me NUTS!!!
I have googled my heart out and cant find a fix. please help
I've updated all drivers, here's my build
I'm using all 3 inputs.. USB gaming head set, back 3.5 port for powered jbl speakers, and optical port for DAC , head phone amp, with audio technica mth a50's
windows 8.1
Asus z87 plus MB/ 4770k bios 2103
corsair 16g ram
250ssd samsung 840
gtx 980
S.M.S.L. DAC
2tb wd hhd
https://www.youtube.com/watch?v=CVPkUv1CpvQ STARTS BAD AT 24 SECONDS
https://linustechtips.com/topic/247243-help-audio-issue-searched-everywhere/
You said it was just via youtube alone, assuming you got a updated version of the flash or browser etc..
Other than that browser are you using?& have you tried it on a different browser?
Details separate people.
1.Disable hardwareacceleration in your browser, google it how to.
2.Remove your overclock -test if it works normal-, if not overclock again. (and remove your ram oc, too. set to 1600mhz or lower)
3.Remove your DAC and test if it does these sounds with analog(connected to your mainboard), test with headphones.
4.If you use your onboard digital output(realtek) open the realtek hd audio manager, change to 24Bits, 48000hz (Studioquality)
5.thank me later.
6.THANK ME NOW!!
hope I could help you, good luck! :D
no, not at all.
i've got a good CPU too, 4770k 4.5
it's not spiking when it happens either.
Maybe a bad OC, try with default clock speed
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
