Hey guys as the title says I am doing my first build. Here is the link to PC Part Picker
I will be getting 2x more 4gb sticks of RAM in the future but don't have the money now
http://au.pcpartpicker.com/p/czFKkL
Any feedback is Great and yes I will be overclocking the G3258
Oh and I have a Hard drive and a Disk Drive to use in this PC
Main PC/Gaming PC - G3258 @ 4.0GHz | Sapphire R9 280 3gb | 2x4GB Kingston Fury HyperX Blue 1600Mhz RAM | ASRock H97M Anniversary | x2 Seagate Barracuda 1tb | Coolermaster N400 Windowed | EVGA 600B 600W PSU | Windows 8
Keyboard, Mouse etc. - Razer Blackwidow Expert 2014 Green Switches | Logitech G502 Mouse | Logitech G430 Headset | Logitech C920 Webcam |
Screens - Acer K27HL | Acer S23HL | 32" Full HD TV (Don't know brand) |
https://linustechtips.com/topic/247191-ma-first-build/
Have fun overclocking on a non overclocking board and a intel stock cooler :). Do you already have a case?
Corsair 350D - ASUS Maximus V Gene - Intel 3770K @ 4.6Ghz - Corsair H100i - G-skill Trident X 2666Mhz 4x4Gb - 2 x EVGA GTX 680 Classified 4Gb @ 1250Mhz - Corsair 860i - 2 x Samsung 840 Pro 240GB (Raid 0)
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3391540
*Headbang*
First of all, all ASUS 1150 boards support overclocking now. They were all unlocked through a bios update. Secondly, the 3258 comes with a copper core cooler that dissipates more heat than the average stock cooler allowing VERY high overclocks on the 3258. The whole point of the CPU is to buy a cheap board and no additional purchase of a heatsink and get a high overclock.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3391610
*Headbang*
It's not an asus board. No matter how fast a copper core can conduct heat it is still limited by the surface area of the aluminium fins.
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3391691
No I am getting the case, but the one I am getting didn't show on Part Picker. And you can overclock on the Board, with a BIOS update, plus I won't overclock to high until I get a Hyper 212 or H80i
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3391766
Oh if you want to know the reason I am getting a expensive (sort off) board is because I want Crossfire, I want to run something like 2x 280x in Crossfire.
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3391771
So it does look like you can overclock on this board you just have to know how to do a bios flash. If your going to do 280x crossfire then possibly save up a bit more money and get a 280x straight out rather than stuffing around with a 750ti.
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3391797
No need for the Flash Update, because the G3258 is Supported by the Board out of the box I can just do a normal update ... I think and the 750 ti will go to a friend probably or in my old Current System
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3391815
@bmwm3186 @Popadookie
How about this, Apparently the 7850 rips the 750 ti to shit
http://au.pcpartpicker.com/p/rWdrt6
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392186
Oh it works out of the box buts needs a BIOS Update for overclocking
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392205
ASRock has done the unlocking on most of their boards as well. I suggest you look that up. I also suggest that you look up the fact that you can OC a 3258 to the moon on the stock cooler. Google it.
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392291
A bios update is a bios update is a bios update...
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392294
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392338
the r7 265 is a rebranded 7850 the r9 270 is a rebranded 7870
@bmwm3186 What should I get?
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392473
@bmwm3186http://au.pcpartpicker.com/p/PPBhGX
Here is the final build, I think. I am deciding whether I want to Crossfire with 2 7850's or just get something like a 280x.
I think I will upgrade the CPU later on down the road to a i5 4690k just so I don't bottleneck high end stuff. But the RAM First
Anyway don't need to be caring about that at this point in time because I am only playing games like CSGO and League of Legends. Also what kind of FPS would I be looking at playing CSGO 5v5 on High @ 1080p, Also I get about a 7-14 ping most of the time if I am playing on Australian Servers
Thanks for the help on this build, If you look you will see I have asked many times for a build like this but don't get the answer I am looking for, someone is always like get a i5 and no Graphics card.... :D Lol,
Okay thanks again
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392667
What kind of FPS would I be looking at for i5 intergrated on csgo
@bmwm3186
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392717
vs like 100 on max... I don't know what to choose, I play at like 40fps on low, 1600x900. Going to go with the G3258 route
https://linustechtips.com/topic/247191-ma-first-build/#findComment-3392746
