CPU is an AMD phenom x4 965 be 3.4
[h=1]MSI 990XA-GD55 AM3+[/h]
I'm considering this motherboard. msi 990xa-gd55 am3+ It has a few bad reviews, but I love the O.C. Genie feature. "I'd rather not try over clocking myself and messing up everything."
My question is what would be the best "cheap" GPU for NOW, just to run video until I can buy a good one. Also, I'm thinking of 2x8 16gb of ram. Could you guys try helping me figure out the best match with this motherboard, or if this mobo isn't a good choice, could you recommend a good one?
https://linustechtips.com/topic/2471-need-advice-on-first-build/
whats your max budget?maybe we could suggest a better build overall.
also do you have a microcenter near you?they have amazing processor and motherboard pricing that could make a huge difference in what you can buy.
http://www.microcenter.com/site/stores/default.aspx
what do you plan to use the pc for?because with 16GB of ram it makes me think a 3d rendering/video editing workstation,but then you have the phenom x4 965 which makes me less sure about that.
and to suggest a gpu we need to know what cheap means for the gpu,to some people <$200 is cheap to others <$50 is cheap.
same thing for the motherboard,we need to know the budget to suggest one.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32842
I don't. =/ I was thinking just to spend 100 on each. maybe a $20.00 gpu to start out with. Then "slowly" upgrading EVERYTHING and eventually using the replaced parts on this PC to build another one.
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32847
What do you need the GPU for? Browsing? Indie games? Newer games?
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32854
so what do you plan to use the computer for?gaming?3d graphics/rendering?video editing?
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32863
Mostly gaming, but I also work with Sony Vegas a LOT.
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32873
if you plan to only use it for gaming even in the future then go with 8Gb of ram,much cheaper and more practical.
http://us.ncix.com/products/?sku=60640&vpn=996995&manufacture=Mushkin%20Enhanced
maybe this motherboard
http://us.ncix.com/products/?sku=62402&vpn=GA-970A-UD3&manufacture=Gigabyte&promoid=1187
as for the gpu I'd consider something like a used 9800gt on ebay or something since it's only temporary.
http://www.ebay.com/itm/XFX-GEFORCE-9800-GT-512MB-VIDEO-GRAPHICS-CARD-DUAL-DVI-TV-OUT-M288-/150983815700?pt=PCC_Video_TV_Cards&hash=item2327563214
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32878
if you need 16GB for sony vegas,I use it and 8GB works for me,then go with this.
http://us.ncix.com/products/?sku=763...r&promoid=1338
although for video editing you may want to consider spending more for intel,they have much better performance on video encoding
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32881
That OC button will mess up things faster than a noob will. Almost all MoBos come with Auto OCing features, all of them are selling points. Heck, my ASUS MoBo has four Auto OC features (two OC switches on the board and two software based OC options. Haven't used one of them.
You also do not need a "990" board unless your are going for like crazy four-way Crossfire/SLI set ups. A cheaper "970" will still do two-way Crossfire/SLI easily.
16GB ram wouldn't be a bad idea for editing, but I easily get away with 8GB in Vegas.
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32903
The O.C Genie feature and other "auto/instant" OC features are just gimmicks, they are useless.
They usually end up doing exactly what a novice overclocker does, which is put way too much voltage on your CPU.
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-32947
Please be patient, save up your money to build a much more future proof computer. You will whinned up spending much more money in the long run if you just jump
into it with both feet. Buying whatever just throwing a sysytem together. Save Up my friend, Please.
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-35549
In my opinion I would check into a FM2 board. Mobo r entry lvl and cheap. Also the CPU is an apu, which is ur processor and graphics inter grated. Could be better if ur no a heavy gamer. I built one for family an he likes bit. Plays bf3 just fine.
I also agree that 8gb is good amount of ram:) u can always upgrade down the road.
https://linustechtips.com/topic/2471-need-advice-on-first-build/#findComment-36336
