Motherboard Issues
Go to solution Solved by TheSLSAMG,
Clear the CMOS, reboot into the BIOS, manually set the speed and voltage without XMP.
So I plugged up my pc and everything booted up and then it worked. But then I went to setting my Xmp profiles to 2133, and now my pc wont boot and then is a red dram led
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/246632-motherboard-issues/
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385274
How would you clear the cmos and worked it void my warranty
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385375
First, please use the Quote button if you want fast responses. Most member do not follow the subjects they post on (I do for the troubleshooting subforum but that's it) and it would help out greatly.
SO.
It won't void anything but your overclocking settings and any other personal settings.
To clear CMOS take out the battery. This is why it's called the CMOS battery. Though I can't be sure, I'm pretty certain that the little silver circle around the PCI slots is that CMOS battery. It should be fairly straightforward to take out. Sit for about 15 MINUTES after taking it out then put it back in.
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385468
SO.
To clear CMOS take out the battery. This is why it's called the CMOS battery. Though I can't be sure, I'm pretty certain that the little silver circle around the PCI slots is that CMOS battery. It should be fairly straightforward to take out. Sit for about 15 seconds after taking it out then put it back in.
Thanks I was typing on mobile at that moment, thus why I couldn't quote
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385534
SORRY 15 MINUTES NOT 15 SECONDS PLEASE READ THIS.
Sorry I was tired when writing this...
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385538
What??
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385633
What??
REMOVE THE BATTERY AND WAIT 15 MINUTES, NOT 15 SECONDS.
Re-read my original comment. You'll see what I mean.
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385641
ok
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385681
SO.
the best way to clear the CMOS is a variation of what you said.
I find doing what you said often does not work.
Best, and fastest way, to clear your CMOS is to remove all power to your PC (unplug from the wall), remove the CMOS battery, hold down the power for 15 seconds (your fans may spin shortly and then stop. you want all LEDS on your mobo to be off) and then put the CMOS back in.
After that, plug it in, turn it on, and it should be reset to default.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385695
Gotta drain them capacitors!
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/246632-motherboard-issues/#findComment-3385844
