So I recently installed a couple of things. I installed my GTX970. I also installed my Noctua NH-U14S but it's just connected to a fan power on the mobo, can't cause blue screen? For a portion the install I took out the CPU and put it back in, I doubt that would be causing this? I'm thinking it's my GTX970, as it's my only true new piece of hardware. I've only gotten 2 blue screens, 1 yesterday and today...but that's enough to be an issue for sure. I have installed a couple new programs, MSI afterburner and Easy Tune 6 from Gigabyte, could they be a factor?
Via GeForce Experience I have checked for the current drivers and are up to date. I did originally install of the CD for drivers though, maybe there is something old that it loaded on? I would assume any old drivers would be overridden by the online update though.
Anyhow, here's a picture of the blue screen if it helps. How can I figure out what's causing this, software, or identify hardware that is causing this and fix it?
post-155082-0-59693800-1415414424_thumb.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
https://linustechtips.com/topic/246622-blue-screens/
snip
It says MEMORY_MANAGEMENT does it not?
Reseat your RAM and try different RAM slots.
What are your system's specs?
https://linustechtips.com/topic/246622-blue-screens/#findComment-3385485
it looks to be a RAM issue.
Run memtest overnight, and try reseating the RAM.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/246622-blue-screens/#findComment-3385678
