I have a asus zenbook with windows 7 on it I brought it to my buddy bc it was working fine then it shut off I turned it back on it said missing operating system so he said he ran a diagnostic repair it took the whole night but everything went back to normal and was fine he said if it happens again means u have a fake windows how do run the diagnostics from bootup please some body help with this???
https://linustechtips.com/topic/246251-asus-zenbook-help-please/
Hey there, @steve518!
What kind of diagnostics did you run on it? Was it just chkdsk?
I'd suggest to boot from the Windows installation disk and choose Repair, afterwards open the Command prompt window
And type these commands:
 bootrec.exe /fixmbr
 bootrec.exe /fixboot
 bootrec.exe /rebuildcd
Afterwards just reboot and hopefully the problem will go away.
You can also try this simple thing, that usually works for new laptops' startup errors:
Unplug the power and take off the battery for fifteen minutes, then connect it again and leave it for another 15 minutes or so before you try to restart.
If these doesn't help, I'd suggest you contact the store you bought it from.
Hope it works though. Good luck! :)
SuperSoph_WD
I hope I can help with any storage issues that you may have!  ;)
https://linustechtips.com/topic/246251-asus-zenbook-help-please/#findComment-3380267
