H440 AIO Radiator placement
So I've recently come by some cheap Kraken X60($80 ish) and figure it's time to reduce the noise. I'm using a h440, and would want to put one in the top to not lose out on the 3.5" bays more than necessary, however, I was hoping to also get a g10 to sort the 290x out. Ideally one or the other would be sorted through the 140mm fan in the back(I'm still not entirely convinced wether the CPU or the GPU would be best served by the larger AIO), but I'm very much so uncertain if it would fit. The other option is of course to put one in the front and one in the top, which would also allow upsizing the second radiator to for example a second x60, but at the cost of drive bays. The other cooler I've been looking at(Also due to a heavily rebated price) is the Antec Kühler 620($40 ish), both which should be compatible with the Kraken G10 bracket.
So I guess my questions are multiple,
Would I be able to fit a 120 or 140mm radiator and fan in the back, while also having one in the top?
Would it be possible to mount the x60 in the top, but aligned towards the front of the case and thus free up space for a backmounted AIO?
Currently the 290x is proving to be a far greater cooling issue than the FX-8350, both in terms of noise and heating up ambient temperature in the case, would it even so make sense to put a stronger AIO on the CPU than the GPU or is that just a rule of thumb, given that the TDP of the 290x is more than double that of the CPU.
How many of the 3.5" trays would you actually have to remove to fit an x60 in the front?
Would I be better off going with a X60 for the gpu and a decent air cooler to sort the CPU?
I went AIo liquid and best decision i have made
I have a 140mm rad at the back pulling air out
280mm rad at the front pulling air in (i had to take out all my drive bays so mounted my storage drive at the bottom)
I also couldnt put the 280 at teh top because it would hit the back 140 since a 280 at the top can only be mounted at the back where the front can be mounted at the top bottom or middle
and 3x120 fans at the top pulling air in
MSI GTX 970 Gaming
I5 with V6 GT
Before Change:
GPU Idle- 50
GPU Full Load- 79
CPU Idle- 45
CPU Full Load- 65
After change
GPU Idle- 27
GPU full Load- 52
CPU Idle- 28
CPU full Load- 42
see this topic for pics
http://linustechtips.com/main/topic/117203-unofficial-ltt-nzxt-h440-owners-club/?p=3371036
SO i suggest a 120/140 AIO for the GPU
And at least a 240 for the CPU
If you go with a 240 for teh CPU you can mount it towards the front of the case at the top which will alllow a 120/140 in push/pull config to fit
