hello,
ok so im confused slightly about the specs of some cards.
do i go for bus bandwidth or memory speed or gpu clocks?
ive seen a card with 4gb ram @ 7000mhz with a 256 bus and another with 4gb but its @ 5000mhz BUT bus is 512 on it. is this the better coice even though it has lower memory clock?
my r9 270x has 5600mhz and 256 bus i think. gpu clocks dont differ much on the cards ive been looking at so i dont think its a main factor?
cheers
https://linustechtips.com/topic/244605-help-with-choosing-pgu/
What GPU's are you comparing here?
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/244605-help-with-choosing-pgu/#findComment-3356822
