First Ever DIY Build
Solved by Aly,
@Ali ,
Glad to hear that you've decided for the WD Black. I really think that you'll like it for gaming.
I've seen different discussions on the 750ti, 770 and 780 comparison. You might find this one (on 750 ti vs 760 vs 770) useful -- http://www.tomshardware.co.uk/answers/id-2032317/gtx-750-sli-760-770.html . You can also compare them on the site gpuboss.com or a similar one. There you can see the main advantages of each.Hope this helps,Titania_WD
GPUboss was really helpful, thanks for that. Just came across the Zotac GTX 970 Amp Extreme, that's hitting the sweet spot with my budget as well
