theres a 7850 for 159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150642
and those $10 give you atleast double the performance of the 650 ti/7770.
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32187
A 6870 may work pretty well for you also http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561 It's about the same price as a 650TI, although the 650TI will probably be more power efficient and have better support in the future. Any dedicated GPU will provide large performance gains over integrated graphics.
"Wisdom III" AMD FX 8120 @ 4.1Ghz // Biostar TA990FXE // 16GB GeIL Black Dragon (8x2) // Saphire HD 7870 OC Edition // CORSAIR TX850M // Curcial M4 64GB (boot) // Seagate Barracuda Green 1.5TB (storage) // Cooler Master Hyper N 520 // Windows 7 Pro 64 bit
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32657
A 500w psu is listed as the minimum for a 6870, while a 400w psu is the listed minimum for a 650TI. You may be better off with the 650TI if OSX supports it. If you have a decent PSU and don't plan on doing alot of overclocking (can you overclock a Hackintosh?) you should be able to run either one though.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32717
A 500w psu is listed as the minimum for a 6870' date=' while a 400w psu is the listed minimum for a 650TI. You may be better off with the 650TI if OSX supports it. If you have a decent PSU and don't plan on doing alot of overclocking (can you overclock a Hackintosh?) you should be able to run either one though. [/quote']
I have a Corsair CX500. Yes, you can overclock on a Hackintosh. Will I be losing performance by going with the 650ti? I probably plan to overclock to maybe 4.2 (I have a Hyper 212 Evo) so I don't know how high I can to go
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32721
I think the 650TI and 6870 will be about the same in terms of performance. It really depends on which one works better with your OS, I don't know anything about Mac's
I also don't know what the actual power draw is for any of these components, especially when overclocked. Try plugging your specs into this calculator and see what you get: http://www.thermaltake.outervision.com/
You can adjust your CPU overclock on with this calculator to get an Idea of how much your cpu will draw at various speeds. I would also factor in some capacitor aging if you're planning on running this system for more than a year or two. You can adjust that in the last box on the page.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32751
A 500w psu is listed as the minimum for a 6870' date=' while a 400w psu is the listed minimum for a 650TI. You may be better off with the 650TI if OSX supports it. If you have a decent PSU and don't plan on doing alot of overclocking (can you overclock a Hackintosh?) you should be able to run either one though. [/quote'] I have a Corsair CX500. Yes, you can overclock on a Hackintosh. Will I be losing performance by going with the 650ti? I probably plan to overclock to maybe 4.2 (I have a Hyper 212 Evo) so I don't know how high I can to go
You will lose a bit of performance from not going with the 7850, but I think the 6870 would be around the same performance, but the GTX 650 ti will be more power efficient(like Railfan S said) and it's newer.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32758
A 7850 will be a good upgrade and in most cases is the best under 180$ card....get a 7850 !!
PC 1: CPU: i5 12600k     GPU: RTX 4080     MOTHERBOARD: Asus B650M-A D4       RAM: 16x4 DDR4 3200       POWERSUPPLY: EVGA 650 G6
SSD: WD Black gen 4 x2 + Crucial MX 500 x2
KEYBOARD: Keychron K4    MOUSE: Logitech G502 SE Hero   MOUSE PAD: Goliathus control XL   MONITOR: Alienware AW3423DW + LG 25UM58 + Dell 24"  Speakers: Edifier R1280T + SVS PB1000
Laptop: M1 MacBook Pro 16
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32760
@RailfanS I used the calculator. I must've done something wrong, because it said 243 watts.
@EChondo I cannot use the 7850 on a Hackintosh so I will have to use the 650 ti or the 6870. I will see which is most compatible.
@Umeshwarnath I can't because I'm running a Hackintosh.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32775
Actually that could be about right, the minimum recommended and what a machine actually draws from the wall can be quiet a bit different. My uncle has a 3770K and 670 in his rig, and when folding (100% cpu usage) it draws about 260-280 watts from the wall. Manufactures often overrate their components so they don't get as many complaints from people using cheap psu's. I did a little more research as well, I found the 650ti is based on a 28nm GPU which is the modern (until the 700 and 8000 series comes out) die size, while the 6870 is based on 40nm architecture. This means the 650TI will be naturally more power efficient. I also found this article on hackintosh GPU compatibility if you haven't seen it yet: http://www.macbreaker.com/2012/06/hackintosh-graphics-cards.html
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32792
Actually that could be about right' date=' the minimum recommended and what a machine actually draws from the wall can be quiet a bit different. My uncle has a 3770K and 670 in his rig, and when folding (100% cpu usage) it draws about 260-280 watts from the wall. Manufactures often overrate their components so they don't get as many complaints from people using cheap psu's. I did a little more research as well, I found the 650ti is based on a 28nm GPU which is the modern (until the 700 and 8000 series comes out) die size, while the 6870 is based on 40nm architecture. This means the 650TI will be naturally more power efficient. I also found this article on hackintosh GPU compatibility if you haven't seen it yet: [url']http://www.macbreaker.com/2012/06/hackintosh-graphics-cards.html
That's actually a VERY reliable site that the article is from. There's a community tonymacx86.com that is used by many who build Hackintoshes. I used for kexts(drivers) and the boot loader. They always have a list of 100% compatible components and the 650 is on it. http://www.tonymacx86.com/248-building-customac-customac-mini-2012.html It does not have the 650ti though. It does have the 660ti. What's the TI mean? Also does it matter what manufacture makes it? Zotac, Asus, XFX, etc.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32801
Sorry for all the questions!
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32814
From what I can tell the ti has more shader or CUDA cores than the 650, which is the reason it performs better. I have no idea what the abbreviation "TI" stands for. Toms Hardware did a review comparing the 650 and 650ti http://www.tomshardware.com/reviews/geforce-gtx-650-ti-benchmark-gk106,3318.html
​As far as manufacture compatibility goes, you'll have to check with some mac guys to know for sure. Keep in mind, the article you linked to is dated 10/10/12, while the 650ti was released the day before (10/9/12) so that could be the reason it wasn't on the list.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32835
From what I can tell the ti has more shader or CUDA cores than the 650' date=' which is the reason it performs better. I have no idea what the abbreviation "TI" stands for. Toms Hardware did a review comparing the 650 and 650ti [url']http://www.tomshardware.com/reviews/geforce-gtx-650-ti-benchmark-gk106,3318.html ​As far as manufacture compatibility goes, you'll have to check with some mac guys to know for sure. Keep in mind, the article you linked to is dated 10/10/12, while the 650ti was released the day before (10/9/12) so that could be the reason it wasn't on the list.
The guide that was released this month: http://www.tonymacx86.com/325-building-customac-buyer-s-guide-january-2013.html still does not list the 650ti, but it does work according to this thread: http://www.tonymacx86.com/general-hardware-discussion/75540-gtx-650-ti-thread.html
As far as the manufacture I think that any is compatible. Is there a performance change though?
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-32861
As long as all the cards have the same clock and memory speeds performance should be the same from all manufactures. Some higher end cards (670's, 680's, 7970's, ect.) have factory overclocked versions, but I don't think that is the case with a 650ti, as it is more of a mid range card.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-34383
theres a 7850 for 159.99 http://www.newegg.com/Product/Produc...82E16814150642 and those $10 give you atleast double the performance of the 650 ti/7770.
30 percent increase. It is still worth the extra ten dollars though, yes.
So True, 7850 FTW :)
  • AMD 7850 - 2GB GDDR5 256bits
  • gBANDWIDTH = 170.2 GB/s
  • gSHADERS = 1024 unified
  • gCPUoc = 1050 mhz
  • gMEMoc = 1330 mhz (x4)
  • gPIXELfillrate = 33.6 GP/s
  • gTEXTUREfillrate = 67.2 GT/s
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-34456
As long as all the cards have the same clock and memory speeds performance should be the same from all manufactures. Some higher end cards (670's' date=' 680's, 7970's, ect.) have factory overclocked versions, but I don't think that is the case with a 650ti, as it is more of a mid range card.[/quote']
Thanks! Will probably get the EVGA one!
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-34499
Okay, good luck. Let us know if it works or not. That way this tread can help others looking for a mac GPU.
https://linustechtips.com/topic/2427-better-than-hd-4000/#findComment-34506
