Problem updating my drivers
Go to solution Solved by Aniallation,
http://support.amd.com/en-us/kb-articles/Pages/AMDCatalyst14-9WINReleaseNotes.aspx
http://support.amd.com/en-us/kb-articles/Pages/catalyst-windows-install.aspx#8
I follow the instructions above every time but once the drivers finish installing my computer just goes to black screen and then put the monitor to sleep. Then when I turn the computer back on I don't get to the log in screen before it crashes and falls asleep. So I have to do a system restore each time.
I'm using windows 8.1 and my gpu is a r9 290 if you need any more info just ask.
https://linustechtips.com/topic/242316-problem-updating-my-drivers/
