Hi
I was looking at this amp as it seems ok and has a pc usb input, but can it power two studio monitors and a sub?
If so how would i connect it up
I dont have much experience with audio and amps so any other suggestions or tips would be great!
thanks guys
EDIT:I dont want a fireball in my room so plz help me if it wont work
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/241520-sony-uda-1/
http://store.sony.com/usb-dac-system-for-pc-audio-zid27-UDA1//cat-27-catid-All-Res-Audio
Not sure about the sub, but it should power the speakers appropriately...
I haven't seen one of these in the local Sony stores that I've been to....
Try checking out stuff from Pioneer as an alternative... I don't think that they come cheap, though...
https://linustechtips.com/topic/241520-sony-uda-1/#findComment-3311384
thanks for a reply, do you know one that i can put on my pc for input and output to speakers and a sub?
My Setup :P
https://linustechtips.com/topic/241520-sony-uda-1/#findComment-3311431
Not really... I was thinking of suggesting a dac and a receiver unit/ speaker amp instead...
I'm not updated in this field since I still work with analog component systems from more than a decade ago...
Sorry, if I wasn't of much help...
https://linustechtips.com/topic/241520-sony-uda-1/#findComment-3311496
@MayflowerElectronics do you know of a setup where the unput is from my pc and output is speakers and a sub
any ideas?
My Setup :P
https://linustechtips.com/topic/241520-sony-uda-1/#findComment-3311867
Look for something with 2.1 support...
iirc monitoring speakers sound good enough even without a sub... Or at least that's what I remember when I saw a Panasonic DJ station showcase at one of the local shops...
https://linustechtips.com/topic/241520-sony-uda-1/#findComment-3311877
i know they sound ok but i want more oomph
My Setup :P
https://linustechtips.com/topic/241520-sony-uda-1/#findComment-3312069
Yeah just get a normal home theater reciever. Most of them take optical audio which your motherboard has built in.
https://linustechtips.com/topic/241520-sony-uda-1/#findComment-3312591
