Hello guys,
im planing to mod my case, i know this is not the ight section of the forum but since the thing i want to know is about air intake and exhaust, i posted it here:
so here are the 2 options:
in the "this" image:
is what i am planing to do, why ?
i dont have any intake fan on the front part of my case, so im using 2 exhausts on the top, and in the back, and as intake the one on the side that i am not cutting,
in the "or" image:
if i would cut all the pannel without letting that fan on there and move it to the front of my case would it give me a good airflow ? since my front part has the hdd and ssd there on the bottom, and the fan would sit right to it would the fan do the work properly as a intake fan ?
thanks!
| Case: Cooler Master Elite 371 | Cpu: i5 4690K @ 4.20 GHz | Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z97 Gaming 3 |
 | Gpu: Gigabyte G1 Gaming GTX 970 4GB GDDR5 | SSD: Crucial MX100 256 GB | HDD: Samsung 128GB Ram: Kingston 8GB DDR3 1333MHz |
| Screen: Benq XL2411Z | Mouse: Logitech G 403 | Mousepad: SteelSeries QcK+ NiP Edition | Keyboard: Steelseries 6GV2 | Headset: Kingston Hyper X Cloud |
https://linustechtips.com/topic/240922-case-air-system/
I hate side fans, nothing ruins a window like hole grills.
cut it all away and put a nice windows there, some white LEDs around the outside to light it up.
edit: have front as intake and top and read as exhaust, if you have an AIO turn the rear as intake to bring cool air for your rad
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302471
my cooler master hyper 212 evo is working like this:
" < " : fans as exauhst
" [  ] " : cooler
(rea one)»  < [   ] <  «(the cooler fan)
i think you can understand :D
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302505
could you not ghetto attach some fans at the front
what you mean :o ?
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302509
what you mean :o ?
Is there any room to maybe sticky tape some fans in the front or screwing them on. Fans arent hard too attach even if there isnt a designated spot
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302517
Its always suggested to have more intake than out because dust.
|| MAELSTROM ||
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302526
" [  ] " : cooler
then rear would be exhaust :)
really though second one is going to look so much nicer :)
This is true but if you hoover your room enough dust really isn't that much of an issue.
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302529
there is a designed spot, the only problem is if i get the fan on the front, the fan place is @ the bottom, but in right front of it there are 2 HDD wich i cant moove, if i moove my new gpu wont fit my case..the problem is if the air will flow properly
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302544
You using the dvd drives? cut them out
|| MAELSTROM ||
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302564
my mom cleans and vacuum the house pretty much every week to dust wont be a problem,its cleaned very frequently,
i really like the option of having the whole side window since would look much much nicer! :)
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302570
when i go home ill see what i can do in the front of my case, i dont, just using 1, but its on the top so doesnt matter! :)
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302574
imalready getting 30º @ iddle, sometimes less with 3.9 ghz... if i play it goes to 45º or less...and its pretty hot in here still... in the winter it wll b e stone cold ..
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302581
if you could get another 2 120 mm in the front that would give nice air flow :)
what drives are you using? could maybe mount them on the bottom of your case and just complete remove the drive cages,
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302592
i think my cage is not removable at all... anyways, i think i could fit atleast the one im using on the side pannel on the front of the case, over the both Hdd and ssd, LIKE:
        ____
        |FAN|
        |_ __|
|disk1|
|disk2|
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302655
If it's me I'd fill up some gt 1850 on the side for the sake of self satisfaction.
whats that? :o
gt 1850 ?
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302713
scythe gentle typhoon 1850 rpm 120mm fans. :)
have a few of them and are silent too (although this depends on the person if he has really Godlike ears >.<)
oh i get you lol :) well if i would get 2 fans in the front of my case and none on the side panel i would have an ok flow ?
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302787
well yes normally. that should work.
so long as you got more intake than exhaust.
example would be.
1 back exhaust, top 1 exhaist, 3 front intake (if this is not possible. a balance 2 exhaust 2 intake is fine. although in most cases depends on the room too I went with 1 exhaust and 4 intake on a old chassis I have.
I remember having this lanboy air something case that has all holes and lot's of fan mounts. and put 15 5400rpm Scyte Gt's and bam all the air goes in was fun though although the 5400rpm one is noisy as fuck :) but the building process feeling was totally awesome. (those 15 fans are all intake >.< )
Live your life like a dream.
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302837
example would be.
i cant get that 3 on intake, on the front,
ant the moment i have 3 exhaust, and 1 intake, i will propable get 2 intake on the front and let the other ones as they are..
my temps are pretty ok for the weather on my country wich is arround 25º during the day...im getting 30º on iddle and 40/45º high load :)
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302863
well if you can put like a dust filter up top, it might be good to put them as intake but seeing your case can have fans at the side you can also put them there :)
but damn those temps are juicy bro.
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302870
yeap they are damn juicy! :)
i had bad temps with stock cooler @ 3.5/3.9 ghz was having arround 50º on iddle during hot days, and 60 on high load...as soon as i bought cm hyper 212 evo, i got 30/35º idle, and 40/45º under load... its pretty good, imvery very happy with this cooler.
about the side fans, i want to cut the pannel and get acrylic on it :P so thats why i created this post mate, :D
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302898
I can visualize the acrylic window on it should look wonderful. how about something that has a tinted window? although I remember doing one before using blue and green acrylic as window.
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302906
i already bought the acrylic, its just a normal one, no colour just transparent :P
also going to get cold cathodes, red ones, and hopefully tomorrow i will buy the "u channel rubber" for the case edge after i cut it :)
https://linustechtips.com/topic/240922-case-air-system/#findComment-3302929
