Get the corsair H105 instead. H100i has mounting issues
Get the EVGA G2 750W instead of RM750
No point in getting WD green really, go for WD blue instead.
At the price you're spending for the motherboard you would be better off with the Asus ROG Maximus VII Hero and a separate Wi-Fi card.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/240516-build-advice/#findComment-3297266
https://linustechtips.com/topic/240516-build-advice/#findComment-3297329
Could you explain why please?
H100i is known to require either force or slight modding almost to fit. H105 does not have these issues.
EVGA G2 750W is simple, go to http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=380 and find the jonnyguru.com review on the RM850 and you will instantly see why.
WD green is build for mass storage to the max like 6TB. WD green is pretty slow to achieve this whereas WD blue/Seagate Barracuda are more balanced between performance, noise and capacity.
Asus ROG Maximus VII Hero (as much as I think they are a bit overpriced) have better power phase designs in general, have some features to improve OC'ing and have SupremeFX sound (Which is pretty darn good) as well as their legendarily good BIOSes.
https://linustechtips.com/topic/240516-build-advice/#findComment-3297365
don't get the i7 4790k instead get 4690k and save some money cuz almost no current game takes advantage of the hyper threading in the 4790k
I5 3570K@ 4.4 - GIGABYTE Z77- Kingston 8G 2400 RAM - MSI GTX980 - HAF-X - 27'' ROG SWIFT + 32'' LG IPS - OCZ 250G SSD + WD 4TB HDD - ASUS XONAR DX -Noctua NH-D14
https://linustechtips.com/topic/240516-build-advice/#findComment-3297369
https://linustechtips.com/topic/240516-build-advice/#findComment-3297451
Black font :(.... Poor Dark Theme users.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/240516-build-advice/#findComment-3297475
