Hey there,
My PC had a bsod memory management. So I was told to take all my RAM out and test 'em one by one. But I have one issue: My cpu cooler. It's the Cooler Master V8 GTS.. It's so big that I have to remove it for taking out RAM....
So if I take my cpu cooler in and out for so many times, I might be busy for a day or 2...
So my idea was to buy a supercheap cpu cooler to easily remove my ram.
Is this the best idea? If not, please share your opinion!
Thanks in advance!
Intel i7-3820/Asus Rampage IV Formula/32 GB Corsair Vengeance Quad Channel (DDR3-1866MHz)/HD 7970 royalQueen (AMD)/Corsair Carbide 300R/Corsair CMPSU-850AXEU/CPU Cooler: Cooler Master V8 GTS
https://linustechtips.com/topic/240470-ram-swap-test-method-problem/
If you have a stock cooler, go ahead and use that one for now, if you don't, and have the time to wait, you can indeed buy a cheap CPU cooler just to test your RAM configuration. Make sure to buy some thermal paste too, if it's not pre-applied on the cooler.
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
I have a few tubes of thermal compound here so I will be ok. Thanks for the quick response!
BTW: any idea what is one of the cheapest cpu fans for an LGA 2011 socket? :P
Wha...? You can use any slot for one-by-one testing. Unless its slot that is reason for error. You should be able to access 1-2 slots without removing cooler. So only 2 remove-reinstalls needed. One to begin testing and another to place everything back again.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
