After reawakening my pc, is freezes and looks like there is a problem with the monitor. Switching off and on the monitor just makes it say that there is no input from the displayport. I then press the reset button, login then restart and that fixes it. I thought it was Nvidia drivers as it only started appearing after I updated them (and nvidia control panel was causing a blue screen when trying to enable SLI which I had never switched off) but after reinstalling them the problem is still there.I am using Windows 8.1 Pro. I recently added the microphone but it didn't require any drivers so I don't why it would be that. Also I have tried using the displayport on the second GTX 780 Ti and it wouldn't fix it. Any help would be greatly appreciated. (I have tried in the troubleshooting thread but no one has replied)
Specs:
i7 4790k
16gb Corsair Vengeance Pro 2133Mhz
Asus z97-ws
Corsair H100i
Corsair Ax860
Samsung 840 Evo 500gb
WD Black 3TB
2x Asus GTX 780 Ti Dcuii OC
Windows 8.1 Pro 64bit
Asus Blu-ray reader
Peripherals:
Lg 34um95-p
Logitech G502
Audio Technica At2020 USB
A standard keyboard (K95 rgb is ordered but isn't really out in UK yet)
GeForce Experience is saying drivers are up to date, I am on version 344.48.
https://linustechtips.com/topic/240066-strange-awakening-problems/
