So i am going to build an new computer and wanted some feedback before i order all the parts :) i will be using the computer mainly for gaming but since i will keep it for many years to come i dont want to limit myself.
Motherboard: Gigabyte GA-Z97MX-Gaming 5
CPU: Intel Core i5 4690K 3,5 GHz, 6MB
GPU: EVGA GeForce GTX 970 4GB ACX 2.0 Cooling
Memory: Corsair 16GB (2x8GB) CL9 1600MHz VENGEANCE PRO RED
Case: Corsair Carbide Air 240 Svart
Power: Corsair RM 550W 80+ Gold Modulär
HDD: 2TB Seagate Desktop SSHD 8GB 7200rpm 64MB
https://linustechtips.com/topic/239887-help-with-new-build/
I suggest going for 8 gb of ram instead of 16, since games don't really go beyond 8 gb of ram right now. Also get two drives instead of a SSHD, a 256 ssd or so and a separate hard drive so you can install os and a few games you like on the ssd.
https://linustechtips.com/topic/239887-help-with-new-build/#findComment-3289433
I would give the Gigabyte G1 Gaming GTX 970 a try and also include an SSD. At least for your OS, be sure to buy an SSD.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/239887-help-with-new-build/#findComment-3289471
If you want useful feedback, you need to give us your budget, your location and what you propose to do with the PC.
https://linustechtips.com/topic/239887-help-with-new-build/#findComment-3289811
well my budget isn't really set in stone, i live in Sweden and was planning to spend around 10 000SEK ~ 1000EUR. What i was planning to use the PC for is mainly gaming but since i want to be able to use this computer for a few years before i start upgrading it i want it to be able to do other things also.
https://linustechtips.com/topic/239887-help-with-new-build/#findComment-3290124
Get 8gbs of ram and don't get the evga 970 get a different design and also get a 212 evo CPU cooler and that PSU is overpriced get a evga nex 650 its way more power than you need but its half the price of that power supply
what design on the 970 should i get ? the evga was the cheapest i think
https://linustechtips.com/topic/239887-help-with-new-build/#findComment-3290240
Praise be tomshardware!
Sweden
Inet
Cdon
Misco Sweden Tigerdirect for Sweden.
Max FPS <--- geared toward overclockers
PCB Hardware Distribution
Baron Dator
Your build is quite solid, but you should do what you can to reduce cost. That PSU has sufficient wattage, but will cost more than a 550w from other reputable brands. If you're just gaming 8GB of RAM is enough. The rest seems ok.
https://linustechtips.com/topic/239887-help-with-new-build/#findComment-3290258
