Im building a new PC, and I'm only certain about the case cpu and video card I want to put in there. For the cpu I'm looking for a AMD FX 8350 or similar, an gtx 970 graphics card and a cool Master storm scout 2 case. I have no idea about the motherboard or anything that would be suitable for this kind of build, but it would be great if it would be relatively cheap. Thanks.
https://linustechtips.com/topic/239630-building-a-new-pc-need-help/
whats the budget and country ?
edit case wich color ?
will this do ? http://ca.pcpartpicker.com/p/hxr499
Maybe put some more wattage in the PSU but otherwise yes, it will do very well. Just make sure you have a nice monitor to enjoy that 970!
why morw wats ? its a 385 MAX TDP watts system  500 is enough
Yeah that looks really good thanks man
no problems :D play around with pcpartpicker if you want a better cooler (h80i for example...)
Using the NZ pcpartpicker:
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($209.95 @ Computer Lounge)
CPU Cooler: Scythe SCMG-3100 88.1 CFM CPU Cooler  ($91.00 @ Paradigm PCs)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard  ($224.00 @ Paradigm PCs)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory  ($113.85 @ PB Technologies)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($159.95 @ Computer Lounge)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($113.85 @ PB Technologies)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($631.34 @ PB Technologies)
Case: Corsair SPEC-03 Red ATX Mid Tower Case  ($97.00 @ Paradigm PCs)
Power Supply: FSP Group 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($141.00 @ Paradigm PCs)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($39.35 @ Ascent Technology)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($149.95 @ Computer Lounge)
Case Fan: Deepcool XFAN 120 44.7 CFM 120mm  Fan  ($9.74 @ Ascent Technology)
Total: $2000.46
Generated by PCPartPicker 2014-10-27 15:32 NZDT+1300
Selection in NZ is crap, I did what I could to choose quality components.
