Bsod code 151 and 145 when oced cpu stressed.
Solved by Volbet,
What would you recommend as a vcore average? I know not all cpus are the same with this.
As you said "not all cpus are the same". This means that it would be very hard for me to recommend a average vcore. I would just go to the point where you begin to feel unsafe about your temps. Those temps should be 75-80 degress celsius, 85 degress celsius max
King Crawford ·
somekidwithanm4 ·
Posted in Cases and Mods0 -
Jackman12 ·
Posted in Graphics Cards5 -
3
GazCBG ·
Posted in CPUs, Motherboards, and Memory2 -
4
1
Ray1ce ·
Posted in Troubleshooting9
play_circle_filled
Latest From Linus Tech Tips:
AMD Is Copying The Worst Thing About Intel - WAN Show May 31, 2024
