Fan Problems
Go to solution Solved by KingDaddyDaniel,
I was still getting fan erorr! when i had it plugged in the motherboard.
Sound like the motor has a short in it. Are both of the fans identical? Do they both make this noise?
Try removing the fans from the case and powering them (WATCH YOUR FINGERS). If the noise is no longer present, then it may just be case vibration.
I had just bought 2 fans from my local computer hardware store, Still have the warranty, But they've started making strange noises
Fan: http://www.newegg.ca/Product/Product.aspx?Item=N82E16835220038
Any ideas of how to fix this problem?
CPU: i7 4770 GPU: GTX Asus 760 CASE: Zalman Z11 Blue COOLER: CoolerMaster Hyper 212 STORAGE: 2TB Toshiba Hard Drive 120 GB SSD
https://linustechtips.com/topic/238577-fan-problems/
Remove it from the case and see if the noise is still present.
https://linustechtips.com/topic/238577-fan-problems/#findComment-3272873
I also get a fan error! press f1, i tried putting then fans on molex and 3pin still same noise
https://linustechtips.com/topic/238577-fan-problems/#findComment-3272885
You usually will if the motherboard detects no fan plugged into the cpu fan header.
https://linustechtips.com/topic/238577-fan-problems/#findComment-3272888
https://linustechtips.com/topic/238577-fan-problems/#findComment-3272891
317 is watching. 317 is everywhere. 317 is life.
https://linustechtips.com/topic/238577-fan-problems/#findComment-3272923
