Hello good folk of the LTT community!
So when skylake released I'm planning on getting a Z170 (Z97 equivalent of skylake) motherboard, an broadwell I7 and the Noctua NH-D15 (Guessing the NH-D15 will also be compatible for LGA 1151). Now my question is this: The NH-D15 comes with 2 NF-A15 fans but what would yield better results? NF-F12's of the NF-A15's?
Just wondering
-Archangel
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/238451-nh-d15-fans/
The A15's are quite better considering the size difference and that they were pretty much made for the NH-D15.
https://linustechtips.com/topic/238451-nh-d15-fans/#findComment-3271538
The NF-A15's that come with the cooler are excellent fans. The difference in temps between the two types of fans would be negligible considering the additional cost of buying NF-F12's.
In my opinion you should just keep the NF-A15's that come with it.
yesterday's weirdness is tomorrow's reason why
https://linustechtips.com/topic/238451-nh-d15-fans/#findComment-3271739
nf-f15 through and  through...
the cpu heatsink fins is more spread apart from each other than your typical watercooled radiator, where nf-f12 finds its place. I doubt there would be a huge difference if nf-f12 was the same size as nf-a15. I would still think nf-a15 would win.
So due to the larger size and all that, nf-a15 would be much better.
https://linustechtips.com/topic/238451-nh-d15-fans/#findComment-3272362
