Sorry for the grammar. Please point out the mistakes so I will learn.
Im building a PC for a friend, Didnt read other threads because parts may be diferent than in my country.
The PC will be DIY, so no exact budget. preferably the cheapest but not Generic Junk...
This is the parts I gathered so far, The cheapest but not junk.
Il ask on suggetstions with each part:
What will be the workload:
Background apps:
Antivirus
Driver stuff
Max load:
Office + Chrome + music player + maybe an antivirus scan + Skype
Cpu: Intel Cpu i5 3470 Tray. (Cheapest I5/I7)  (Should I go for amd and find cheaper Cpu?)
MB:  GA-B75M-D2V
Ram: Adata 4GB DDR3 1333 240PIN CL9  (4 Should be sufficient, Later on can ad another 4 if neccessery, MB supports up to 2 Ram Sticks)
         OR  Lingston KVR16N11S8/4  4GB 1600 CL11
Case:  Here im a bit lost, I have a Fractal design R4 myself, So would like to hear suggestions.
           What wil be needed from a case: Can be opened from both sides. Places for cables(Like the R4), HDD bay removable or small. Front USB and
           sound. USB3 ofcourse. easy to manage.
Cpu Cooler: Cheapest from a brand: Arctic Alpine 11.  My preference Schyte katana 3.
                    If there is some other cheap good cooler I dont know, Please suggest.
PSU:  One that come with a Case OR  corsair VS350  OR  Antec VP350P  OR  Seasonic ss-350et. My preference :Seasonic 400W ECO SS-400BT
SSD: Cheapest SSD: Sandisk 128GB SDSSDP128G  OR  Kingston SSDNow 120GB SV300S37A/120G OR        SanDisk Ultra Plus SSD 128GB  SDSSDHP128G OR Crucial 120GB CT120M500SSD1.
            My Preference Samsung 840 EVO 120GB MZ7TE120BW
Monitor: Here again a bit lost in the market and there might be some cheap gems I dont know about.
             What needed:  1080P,  HDMI, DisplayPort(Optional), VGA, DVI, Acceptable MS(High Speed moving movies), Not TN.
Keyboard Mouse: Not neccesery, If you have some reccomended cheap combo or individuals would like to hear suggestions.
Mouse PAD:  Not neccesery, If you have some Cheap Gems glad to hear.
Speakers: A 2.1 Set, Cheap but reccomended.
Headphones: Not needed.
Case Fans: What comes with a Case, If theres none, Some quiet reccomended ones.
https://linustechtips.com/topic/238443-quality-cheap-home-pc/
get an AMD APU instead of the i5 doesn't look like he will need that much cpu power and the integrated on the APU is better then the Intel no reason to spend 100$ more on something unnecessary
Which one will you suggest from this:
Prices in USD Direct conversion:
48$ AMD A6-3670K Socket FM1
50$ AMD A4-3400 Tray
52$ AMD A4-4000 with Radeon HD 7480D Tray
53$ AMD A6-3870K Box
61$ AMD Richland A4-4000 Box
68$ AMD A6-5400K Trey
69$ AMD A4-5300 with Radeon HD 7480D BOX
74$ AMD Dual Core A-Series A4-6300 HD 8370D Box
79$ Processor AMD A6-5400K Black Edition
106$ AMD A6-6400K with Radeon 8470D Box
What do you mean there is no budget since it is diy? Your preferences are the better options.
The prices may differ so putting a number wont help much. Thats why I listed the parts I found that the cheapest.
My preferences is products from companys that I use myself or reccomended somewhere else, If the cheaper options still ok or there is other options cheaper than my pref' than I will use it.
For a cheap budget case you can look at the nzxt source 210, nzxt s340, bitfenix shinobi, and my favourite budget case, the bitfenix shadow.
210 dont have USB3, s340 is not in stock in my country, Bitfenix is unavailable in my country.
https://linustechtips.com/topic/238443-quality-cheap-home-pc/#findComment-3271645
