well that should get you back up n running, so the origin drive? did you RMA it?
Hard drives none SSD usually have 5-10 years Warranty's
I RMA drives i find lying about lol! some people just don't seem to understand that.
note they wont recover your data!
but if hte drive is still spinning you can use a usb caddy and something llke 'get data back NTFS' to recover the actual data
ICT professional, Addicted to PC
https://linustechtips.com/topic/237890-hard-drive-problems/#findComment-3262454
go here :
http://support.wdc.com/warranty/
and check the warranty status, they may need the actual fault codes before they will replace it but if its seized or not spinning and not damaged from a drop or something they should replace.
https://linustechtips.com/topic/237890-hard-drive-problems/#findComment-3262504
Is the serial number S/N?
Yes
  •     | CPU- AMD FX-8350 @ 4.0 Ghz | Motherboard - Asus M5A99FX PRO R2.0 | RAM - G.Skill Ripjaws X 16GB 1333mhx (2X8GB) | GPU - Asus Radeon R9 280 @ 980mhz | Case - Antec GX500 | Storage - Western Digital Purple 3TB 5400RPM | PSU - Corsair CX750M |
   | Display - Asus VW246H 1080p @60Hz 2ms GTG | Keyboard+Mouse - Logitech S510 | Sound - Realtek Intergrated Audio :( | Case Cooling - 3x Antec Stock 120mm fans (Planning to add more) | Headset - Turtle Beach X12 with virtual surround | OS - Windows 7 64 Bit Pro |
https://linustechtips.com/topic/237890-hard-drive-problems/#findComment-3262548
