Hi guys I need help with picking a gpu for my system I'm debating wether to get a r9 270x (£120/$190) or r9 280(£130/$210) my budget is about £130/$210.i would like to game in 1080p (60Hz) and mostly AAA titles any suggestions will be considered.Thanks
system:
AMD fx4200 4.2GHz
12GB ram
120gb SSD and 1TB HD
500W with 38amps on 12v rail
https://linustechtips.com/topic/237834-need-help-picking-a-graphics-card/
Definitely 280.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
If you can find a 280 for under £130, then go for it. Otherwise, a 270X will be fine.
(The cheapest 280 in the UK starts at ~£150)
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
280 + OC
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
What sort FPS do you guys think I'll be getting playing titles like bf4 F1 2014 and other racing sims at 1080 and do you think I'll be able to play most of them at high/ultra?
Also I might be able to get a sapphire 280x oc (about 3-4 months old) of a friend for about £145/150 do you guys think it's worth the jump for an extra £20 and what FPS difference that will make?
Thanks for the responses so far.
