Watercooling options help
Solved by Oshino Shinobu,
You should be able to mount one on the rear fan slot, or on either of the two at the top. You could put a 240mm in the top.
As for the front, I'm not sure. There won't be as much airflow in the front as there is in the top because the front doesn't have much ventilation.
Doctah ·
Posted in Peripherals0 -
2
michaelb198 ·
Posted in Peripherals1 -
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards3 -
12
6
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies4
play_circle_filled
Latest From ShortCircuit:
