1. Budget & Location
budget is 1500 with tax (13%) location london ontario
2. Aim
my aim is to do a lot of maya rendering and some serious gaming
and i also need it to have a i7 4790k
3. Monitors
1 monitro nothing less than 1080:1920
4. Peripherals
yes i need a mouse and keyboard and i already have windows
5. Why are you upgrading?
im not
thanks
Cpu: i7 4790k Mobo: Asus z97-A  PSU:Ultra Semi-Modular 850w SSD: Kingston 240gb HDD: Segate 1tb Ram: 2x8gb G.Skill ram GPU: Zotaz GTX 980 AMP! Case: Fractal Design Define R4 Windowed
https://linustechtips.com/topic/236915-pc-build/
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/236915-pc-build/#findComment-3248494
Please read http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/  before posting, im going to assume this is for gaming though,
do you need windows?
where are you from?
why do you need a new pc?
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($144.99 @ Newegg)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($69.99 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($329.99 @ Amazon)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($109.99 @ Micro Center)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Total: $1224.91
Generated by PCPartPicker 2014-10-21 20:34 EDT-0400
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/236915-pc-build/#findComment-3248512
Where do you live, what do you want to do with the pc, do you need windows, any other wishes etc......you should put in a bit more information.
there fixed thanks
on the info
https://linustechtips.com/topic/236915-pc-build/#findComment-3248522
Here it is @mostechtips. It's a bit overbudget since I don't want to cheap out on the Power Supply.
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($358.78 @ DirectCanada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($33.07 @ DirectCanada)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard  ($139.95 @ Vuugo)
Memory: A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600 Memory  ($152.78 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($56.98 @ DirectCanada)
Video Card: EVGA GeForce GTX 970 4GB ACX Video Card  ($369.99 @ Memory Express)
Case: BitFenix Merc Beta (Black) ATX Mid Tower Case  ($31.58 @ DirectCanada)
Power Supply: Cooler Master VSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($93.98 @ Newegg Canada)
Monitor: LG 23MP55HQ-P 60Hz 23.0" Monitor  ($164.99 @ NCIX)
Keyboard: Cooler Master Storm Quick Fire Pro Wired Gaming Keyboard  ($84.00 @ Vuugo)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($61.98 @ DirectCanada)
Total: $1548.08
Generated by PCPartPicker 2014-10-21 20:47 EDT-0400
https://linustechtips.com/topic/236915-pc-build/#findComment-3248633
I would never buy a $100 Coolermaster PSU, especially at damn near $100 when you can get much better ones.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/236915-pc-build/#findComment-3248802
Total: $1548.08
Thanks a lot
https://linustechtips.com/topic/236915-pc-build/#findComment-3248812
Few $ over. But this is a fucking beast!
CPU Cooler: Zalman CNPS10X OPTIMA CPU Cooler  ($21.99 @ NCIX)
Storage: A-Data Premier Pro SP600 256GB 2.5" Solid State Drive  ($103.98 @ DirectCanada)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($379.99 @ NCIX)
Case: Corsair 200R ATX Mid Tower Case  ($59.22 @ DirectCanada)
Monitor: AOC i2267Fw 60Hz 22.0" Monitor  ($139.99 @ Canada Computers)
Case Fan: LEPA Vortex 12 PWM 63.9 CFM 120mm  Fan  ($0.99 @ NCIX)
Total: $1506.41
Generated by PCPartPicker 2014-10-22 07:59 EDT-0400
https://linustechtips.com/topic/236915-pc-build/#findComment-3251572
