I recently bought a second GTX 770 for my gaming rig for 1440p gaming, but I can't seam to get the new graphics card and the old one to work together. The computer recognizes both but every benchmark I have only recognizes that I have one installed, I don't know what to do please help!!!
Before anyone askes yes I did put the SLI connecter on
https://linustechtips.com/topic/235072-gtx-770-sli-help/
Did you turn SLI on in the NVidia control panel?
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
https://linustechtips.com/topic/235072-gtx-770-sli-help/#findComment-3220368
I could not find the setting
If theres still such an option, it should be under 3D settings
https://linustechtips.com/topic/235072-gtx-770-sli-help/#findComment-3220410
it might be possible that i have a faulty SLI bridge but not likely, my MB is the asus x79 deluxe
Okay, if you're sure.
The only things I can think of is you're running an AMD board that doesn't support SLI, the PCI lanes on your motherboard are dead, or you have a faulty SLI bridge.
https://linustechtips.com/topic/235072-gtx-770-sli-help/#findComment-3220553
