Help Me?
Go to solution Solved by Demons Wrath,
http://uk.pcpartpicker.com/p/2pHKNG
What do you think of this
i am trying to stick to your build but i cannot help but have a little touch of my own :)
It's not as good. You're wasting money on a more expensive gpu that will perform the same. What's more you're offsetting the price by going with a cheaper mouse, inferior cooler and case.
Put quite simply; 'your touch' is making your pc worse.
Hello friends of the internet.
Recently I was getting bad results from my old toshiba laptop and wanted to build a gaming pc.
I have never built before however I have modified pc's and I am pretty sure I know what I am doing.
I have a budget of £600 including mouse and keyboard. This does not include the monitor.
I also require the rig to be Intel and Nvidia based for no particular reason whatsoever.
I would really appreciate it if you could help me by suggesting changes to this list I have already created!
total: £600.23
https://linustechtips.com/topic/235069-help-me/
Get 4690K and 1866Mhz RAM
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
https://linustechtips.com/topic/235069-help-me/#findComment-3220302
total: £600.23
you really made this by yourself?
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
https://linustechtips.com/topic/235069-help-me/#findComment-3220304
You can get compatible 4690K for about 10$ more (H97)
https://linustechtips.com/topic/235069-help-me/#findComment-3220336
total: £600.23
here intel and nvidia... tho you could do a better deal with amd.
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  (£158.00 @ Aria PC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  (£61.26 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 760 2GB WINDFORCE Video Card  (£142.79 @ Aria PC)
Case: Zalman Z5 ATX Mid Tower Case  (£28.34 @ Amazon UK)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£35.82 @ Amazon UK)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£10.09 @ CCL Computers)
Case Fan: NZXT FN-120RB 47.3 CFM 120mm  Fan  (£5.98 @ Scan.co.uk)
Mouse: Gigabyte GM-M5050 Wired Optical Mouse  (£3.50 @ Amazon UK)
Other: RAZER DeathStalker Essential Black Wired Keyboard (£49.99)
Total: £598.66
Generated by PCPartPicker 2014-10-18 18:01 BST+0100
But is ok.
https://linustechtips.com/topic/235069-help-me/#findComment-3220379
CPU Cooler: Zalman CNPS10X OPTIMA CPU Cooler  (£17.98 @ Scan.co.uk)
Motherboard: ASRock Fatal1ty H97 Killer ATX LGA1150 Motherboard  (£55.99 @ Amazon UK)
Case: Zalman Z3 Plus ATX Mid Tower Case  (£34.68 @ Scan.co.uk)
Power Supply: Zalman 550W 80+ Gold Certified Semi-Modular ATX Power Supply  (£47.68 @ Amazon UK)
Case Fan: Arctic Cooling Arctic F12 74.0 CFM 120mm  Fan  (£3.83 @ Aria PC)
Keyboard: Zalman ZM-K500 Wired Mini Keyboard  (£30.60 @ Scan.co.uk)
Mouse: Cooler Master CM Storm Xornet Wired Optical Mouse  (£14.84 @ Amazon UK)
Total: £607.41
Generated by PCPartPicker 2014-10-18 18:20 BST+0100
GTX 760, good mobo (even looks nice!), 4690, good case +1 fan for it, mechanical keyboard, gaming mouse. Nothing out of the ordinary.
https://linustechtips.com/topic/235069-help-me/#findComment-3220479
Hi again!
~~~UPDATE~~~
I wanted to update some stuff from earlier so here goes!
Can I mention that in the future overclocking is something I would definitely want to do.
There were a lot of comments mentioning that I should upgrade my cpu to the Intel I7 4690k because it is 4th gen and only £10 more expensive.
I agree, this is a fairly good upgrade for £10 and it also supports overclocking to my needs.
I also want to say that I would like to "attempt" to overclock my gpu/graphics card so I will need a good graphics card.
Also many people were mentioning that I should have the gtx 760 by Gigabyte but I want to stick with the EVGA card because my last pc had an EVGA and it was reliable.
List:
http://uk.pcpartpicker.com/user/Ajef_981/saved/2T7scf
Yognaught and Proud!
https://linustechtips.com/topic/235069-help-me/#findComment-3221031
It's around £20 more
Total: £623.83
Generated by PCPartPicker 2014-10-18 19:23 BST+0100
https://linustechtips.com/topic/235069-help-me/#findComment-3221050
this makes it cheaper :)
Also makes it worse. If I comb through your build vs mine.....
The cooler is vastly inferior for £2 less. The RAM is £10 more. The case is £20 more. PSU is £17 less, but is also less efficient. Mobo is from the older gen Haswell stuff, fortunately you do not require a Z series mobo anymore to overclock. The B and H class mobos can do it too. The fans are more expensive and you need to buy more of them for that case.
The most glaring thing in your build is this is a gaming pc, and you've spend by far the most on the cpu rather than the GPU. This is a gaming pc, or supposed to be, and you're not going to invest the most in your GPU? This is madness! Do the sensible thing. At least consider my build. In fact, if you change the cpu from the 4690k to the G3258, that might be what you need. Hard to say. Tell me which games you plan on playing with this.
https://linustechtips.com/topic/235069-help-me/#findComment-3221120
Games:
Minecraft (maybe)
TF2 (for sure!)
Battlefield 4
Dota 2
Tom clancy's ghost recons
There are loads of other games as well
I also want to mention that I make youtube videos (gaming) and require to do some simple editing
I want to thank you for your help and I want to keep an i5 and might consider a different build as long as it is as close to my build as possible. I could probably up the budget to £625 if needed to but if not i would like to stay as close to £600 as possible.
https://linustechtips.com/topic/235069-help-me/#findComment-3221166
Games:
Minecraft (maybe)
TF2 (for sure!)
Battlefield 4
Dota 2
My build is £623!  :D
Trust me, I'd go for it. For the price it's an an excellent PC. It's budget priced, but mid ranged level gaming PC. I'm actually surprised it has a 4690k at all for the price.
https://linustechtips.com/topic/235069-help-me/#findComment-3221242
I would also like to ask a question!
At the bottom of the partpicker page it says that I might need to update the motherboard bios prior to using the haswell cpu.
Unfortunately I do not have another cpu lying around
What do you suggest?
Video Card: Asus GeForce GTX 760 2GB DirectCU II Video Card  (£142.84 @ Aria PC)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  (£30.18 @ Amazon UK)
Total: £606.38
Generated by PCPartPicker 2014-10-18 20:10 BST+0100
This. £8 more, totally worth the extra few quid.
https://linustechtips.com/topic/235069-help-me/#findComment-3221382
What about the question?
what do you suggest if I wanted to keep the pc I customized myself?
You would need another cpu to update the bios I would think. And your build isn't well priced. That's why you're here isn't it? To ask for advice? I have just given you advice. The build for £8 more is a no brainer. No update required. A more economical build.
https://linustechtips.com/topic/235069-help-me/#findComment-3221445
https://linustechtips.com/topic/235069-help-me/#findComment-3221544
