Hey guys, so unfortunately i have to send my PSU(XFX pro series 750w) back as every so often it wont turn on and of coarse they don't have any left in stock so they can't give me another one. I want at least a 750w, but an 850 would be nice cause i wanna future proof. I have a budget of around £80. Any opinions?
i found this one,
Specs
mobo: Asus sabertooth 990fx r2.0
GPU: R9 280x
CPU: FX 8350
PSU: XFX pro series 750w
HDD: WD 1TB
RAM: crucial tactical tracer 2x4gb, 1600
Thanks
https://linustechtips.com/topic/234944-best-power-supply/
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/234944-best-power-supply/#findComment-3218446
Unfortunately i cant afford that lol
Then take that Supernova. I only have heard good things about it :)
https://linustechtips.com/topic/234944-best-power-supply/#findComment-3218482
something from seasonic.
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
https://linustechtips.com/topic/234944-best-power-supply/#findComment-3219419
Cooler Master V750?
  • 80+ Gold Efficiency
  • Semi-Modular Design
  • Quality 100% Japanese Capacitors
  • $110
There is also the Corsair CX750M:
  • 80+ Bronze Efficiency
  • $90
Or the Corsair CS750M:
  • ATX12V v2.4 and EPS 2.92
  • $110
Whichever one fits your budget.
kompooterz.
https://linustechtips.com/topic/234944-best-power-supply/#findComment-3219677
