PSU Advice... PLS :)
Solved by raultherabbit,
For that price you could have this:
So get that instead just by reviews and marks alone. My $0.02. Also, I own it and it's great!
Disregard that I totally didn't finish reading the post. Unless your current power supply isn't working I wouldn't bother. You're not going to get any better performance out of it. If both power supplies are about the same age then you're looking at probably the same MTBF.
