Blackscreen when power on
Go to solution Solved by bry.yyyy,
dammit,can you grab any other graphics card to verify that the problem is the GPU?
no i guess i will take this card to my local store and grab my warranty
btw thanks for help
hi guys i got problem here
so i recently plug the VGA Cable to my GPU (HD 5570) And got a blackscreen
but when i use onboard graphics no blackscreen all working
can i get solution on my GPU ?
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/234390-blackscreen-when-power-on/
connect a diffrent cable and check what you get,it might have died.
still same
if it has power connectors,make sure they are connected and that the card is connected to the PCI slot correctly.
no the card doesn't have Power connector
it already connected to the slot correctly
still no work
do you have more pci slots on your mother board? move it around to a diffrent slot and try again
no i don't have just 1 PCI-E 3.0 Slot x16
btw thanks for help
