Hi there!
I was wondering if anyone in the BC/AB/SK region (else where is fine but shipping can start getting expensive) did cable sleeving at all for PSUs? I'm looking to get mine done, and possibly do it myself, or outsource it to someone from here.
Thanks!
You can buy cable extensions which is easy and no risk of breaking cables or doing something wrong, I have the H440 case so my PSU and majority of cables are hidden, I got Red sleeved cables for the cables that come back into the case and are visible
http://www.bitfenix.com/global/es/products/premium-modding/alchemy-cables/
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/234322-psu-cable-sleeving/#findComment-3202548
I am doing a psu sleeve job right now, and I can say that it's not that hard, just time consuming. I bought 550 paracord off eBay for under $10 for 100 ft. And a set of tools for $15. In all I spent under $40. (I did go over board on the cord though...just in case)
I am going with a heat shrink-less method, and it looks great. A couple oops moments so far, like cutting a cord just right.. Just to melt the end and watch it shrink up on you.... But still. On a newbie scale. I would give this a 3 on being hardness.
You said Floppy......
https://linustechtips.com/topic/234322-psu-cable-sleeving/#findComment-3272835
