Hi I have a question about z-index because i am fairly new to the property.
Can I have 3 div's like this
<div class="div1">
     <div class="div2">
         <div class="div3">
           </div>
     </div>
</div>
My idea is can i make div 1 with the lowest hierarchy out of the three and div 2 and div 3 with the highest.
I was planning  on putting a transparent gradient layer over  the body  but I want the content to not be affected by the gradient.
Is this possible?
https://linustechtips.com/topic/234257-css-z-index-help/
<div class="div1">
     <div class="div2">
         <div class="div3">
           </div>
     </div>
</div>
Is this possible?
There's a CSS property that no one knows about called pointer events. It controls what happens when a user clicks, hovers or basically does anything CSS related with the mouse. By setting pointer-events: none; on the overlay, it tells the computer to basically ignore any mouse stuff on the overlay. Here's my code stuff:
<head><style>.div1{	position: fixed;	z-index: -99;	width: 100%;	height: 100%;	top: 0;	left: 0;}.div2{	position: fixed;	z-index: 99;	width: 100%;	height: 100%;	top: 0;	left: 0;}.div3{	position: fixed;	z-index: 999;	width: 100%;	height: 100%;	pointer-events: none;	top: 0;	left: 0;	background: -moz-linear-gradient(top,  rgba(0,0,0,0.65) 0%, rgba(0,0,0,0) 100%); /* FF3.6+ */background: -webkit-gradient(linear, left top, left bottom, color-stop(0%,rgba(0,0,0,0.65)), color-stop(100%,rgba(0,0,0,0))); /* Chrome,Safari4+ */background: -webkit-linear-gradient(top,  rgba(0,0,0,0.65) 0%,rgba(0,0,0,0) 100%); /* Chrome10+,Safari5.1+ */background: -o-linear-gradient(top,  rgba(0,0,0,0.65) 0%,rgba(0,0,0,0) 100%); /* Opera 11.10+ */background: -ms-linear-gradient(top,  rgba(0,0,0,0.65) 0%,rgba(0,0,0,0) 100%); /* IE10+ */background: linear-gradient(to bottom,  rgba(0,0,0,0.65) 0%,rgba(0,0,0,0) 100%); /* W3C */filter: progid:DXImageTransform.Microsoft.gradient( startColorstr='#a6000000', endColorstr='#00000000',GradientType=0 ); /* IE6-9 */}</style></head><body><div class="div1">          <div class="div2">	 <button>Click me</button><br>		Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.         <div class="div3">			           </div>     </div></div></body>
And here is a fiddle showing it in action http://jsfiddle.net/49omtjfz/1/
I should warn, there is a reason it's not well known. As always, Internet Explorer just doesn't like it. There is a workaround, but you'll have to look it up because I can't remember it because all IE workarounds are horrendous. But it's not just IE. For example, I tried it in Chrome and it simply didn't work, worked in firefox through and it also works in the fiddle... So, I'd avoid it if I were you. You can probably do it with javascript... Getting the click and the mouse cursor position and simulating the click on the layer you want it to..... But that's probably more effort than it's worth
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
https://linustechtips.com/topic/234257-css-z-index-help/#findComment-3201947
Is this possible?
it is possible and it is the default behaviour, you don't even need to use z-indexes because div1 will be on top of the body by default
just set the background-color property for div1, so that it's not transparent and you don't see the background gradient
https://linustechtips.com/topic/234257-css-z-index-help/#findComment-3211411
