Hi. I have a problem that has been occuring for quite some time.
To not write too much here is my video of it.
https://www.youtube.com/watch?v=rAV3YAKuTM4&list=UU6nA3hxyBDHWo_8ONS81csQ
The GC has been OC before this happened but as soon this problem occured I have gone back to defaults.
The only thing changed is my HDD which is now Seagate 500GB.
It's not related to DVI cable because as soon I unplug the primary monitor this "jumps" to secondary.
Thank you for any help.
https://linustechtips.com/topic/233527-display-problem/
It looks like a broken panel, but it could be other things.
Have yout tried the monitor with a different PC? or a different plug on the monitor itself? (VGA, HDMI or Displayport)
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/233527-display-problem/#findComment-3191047
It could not be display problem because when I unplug my monitor the second monitor (TV) becomes first display and it happens to it. As is said it "jumps" as soon as unplug first display.
https://linustechtips.com/topic/233527-display-problem/#findComment-3191323
Ok I don't know if it can be caused by this. In my CCC I found that I had DVI alternate operational mode on. It says it should be used if I'm expericing display corruption but until the problem I didn't whilist it was on. Could that be it?
https://linustechtips.com/topic/233527-display-problem/#findComment-3191363
Another problem occured. Now after the first problem is showing up and in few seconds diapppear the entire monitor looks like there is serious problem with it. All the text is blur and nearly unreadable.
Please any help? :C
Your monitor is most likely good. I'd troubleshoot it and see if it occurs with another monitor. Set GPU to default clocks. Looks like a driver issue because it's not doing it to the other display.
Main: i7 2600 | ASUS P8Z68-V | 2x4GB Vengeance 1600 | GTX 580 | WD Blue 1TB | Antec TP-650C | NH U12S | W7 x64
Backup: X6 1090T | MSI K9A2 Platinum | 4x2GB XMS2 800 | GTX 550Ti | WD Blue 1TB |  Antec VP-450 | CM TX3 | W7 x64
https://linustechtips.com/topic/233527-display-problem/#findComment-3194559
Ok I have set it defaults of original R9 280X which is 1000Mhz and 6000Mhz.
Then I guess I need to completly re-install drivers.
It's weird because it all started with HDD I had to have installed. Now I'm waiting for money to come through to buy SSD. Maybe new Windows+drivers on SSD will fix the issue, but that will be in another 2 weeks :C
https://linustechtips.com/topic/233527-display-problem/#findComment-3196086
