Need some anti-DoS help
just saying, I've had no DDoS issues ever so I think if you're not using any software with risks of DDoS (skype bug) then I think you dont need to do anything more than just your router's Firewall.
Depending on your router, the setup page will almost certainly have a security page. Look around there
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/233186-need-some-anti-dos-help/#findComment-3186549
I would normally agree with you with just the router's firewall, but it doesn't seem to help.
My brother showed me a user who was flaunting himself via Twitter as he was tweeting about taking down my brother's stream. Around the time he tweeted "DOWN @<brother's account>" my network would not connect to the internet. My modem was saying the internet was fine, but we had no connection whatsoever.
https://linustechtips.com/topic/233186-need-some-anti-dos-help/#findComment-3186557
A DoS attack is a Denial oService attack. Basically, the attackers send so much data to your house (usually through an NTP or DNS reflection) that you cannot get any of your own data through the line (overloading it).
Sadly, in a consumer environment, there's not much you can do to prevent/mitigate a DoS attack. The best you can do is contact your ISP and see if they'll do anything.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/233186-need-some-anti-dos-help/#findComment-3186562
Because he had a hard drive.
https://linustechtips.com/topic/233186-need-some-anti-dos-help/#findComment-3186578
How would they change your IP?
Yeah, either its static or you automatically get chosen one.
https://linustechtips.com/topic/233186-need-some-anti-dos-help/#findComment-3186616
Ok then, you have more post than me. That means you are right, right?
ISPs hand out the address on their network, so yes, they can change them (does not mean they will, but they can).
15" MBP TB
https://linustechtips.com/topic/233186-need-some-anti-dos-help/#findComment-3186767
