http://pastebin.com/gFn2zSXT
In the for loop part when trying to have it stop when placement is less than 10. It continues and displays 16 which is the 2^4.
Thanks,
Case: NZXT Phantom Green Trim   Graphics Card: EVGA GTX 670 2gb FTW    CPU: Intel i7 4770k 3.5GHZ    Motherboard: Gigabyte G1 Sniper 5   Hard Drives: One Western Digital 1TB & Hitachi 1TB   Power Supply: Corsair RM 850w
Cooler: Corsair H80i Liquid Cooler    Ram: Corsair Vengeance 2x4gb & Mushkin 1x4gb   Monitors: Two Asus 22'' 1080p monitors   Keyboard: CM Storm Quickfire XT Green   Mouse: Razer Naga 2014   Microphone:  Audio- Technica AT2020 XLR with a Alesis MultiMix 4   Headphones: Sennheiser HD 280 Pro
https://linustechtips.com/topic/232687-mathpow-problem-c/
The issue is that it increments before the loop ends.
It will print placement = 8 (2^3) then it will itterate pt to 4. it will run through the loop, set placement =16 (2^4), then print it, then it leaves the loop as 16 !< 10.
On a side note, just for the sake of clarity, I would just initizlize double pt and double placement without assigning any values.
 		static void Main(string[] args)			        {			           string numPeoplestr = "Enter the number of people in the group";			           double numPeople = 10;			           double pt; placement; 			 			           double[] pa = new double[10];			 			           for ( pt = 1;  placement < 10; pt++)			           {			 			               placement = Math.Pow(2, pt);			               Console.WriteLine(placement);			 			           }			}
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/232687-mathpow-problem-c/#findComment-3180427
Is there anyway that I can have it stop before it gets the value of sixteen while still using the powers of 2.
https://linustechtips.com/topic/232687-mathpow-problem-c/#findComment-3180568
You could use a do while loop instead of a for loop. That way it'll check the condition at the end of the loop instead of the start.
double pt = 1;double placement = 0;do {    placement = Math.Pow(2, pt);    Console.WriteLine(placement);    pt++;} while (placement < 10)
https://linustechtips.com/topic/232687-mathpow-problem-c/#findComment-3180712
Hmm I some how figured it out by reordering it the the write line and placement equals. http://pastebin.com/gFn2zSXT
Edit:
Nevermind it did this instead 2, 2, 4, 6, 8.
https://linustechtips.com/topic/232687-mathpow-problem-c/#findComment-3180820
Also how did you put the body of code in your reply instead of doing something like pastebin?
https://linustechtips.com/topic/232687-mathpow-problem-c/#findComment-3180826
Edit:
After the first call to
double placement = Math.Pow(2, pt);
You don't increment pt. Your loop needs to be started at 2 instead of 1.
https://linustechtips.com/topic/232687-mathpow-problem-c/#findComment-3181473
Nevermind I figured it out. Probably a janky way but whatever.
https://linustechtips.com/topic/232687-mathpow-problem-c/#findComment-3200175
