Need more internal USB Headers
Go to solution Solved by W-L,
Hi guys,
I have a got Asus Rampage V Extreme, a PSU AX1200i, a CPU Liquid Cooler NZXT Kraken x61 and the case Corsair 750D. So total internal USB 2.0 headers required are:
1. Motherboard OC Panel
2. Corsair Link
3. NZXT Kraken x61
4. Front USB Panel of the case
So a total of 4 internal USB 2.0 Headers are required and I have only 2 available. So can I know what solution is available to me to add more internal USB 2.0 headers.
Thank You
If you want them to be internal then something like this should do since you will only need USB 2.0 ports:
http://www.legitreviews.com/nzxt-iu01-usb-2-0-internal-expansion-hub-review_1293
Hi guys,
2. Corsair Link
3. NZXT Kraken x61
Thank You
https://linustechtips.com/topic/232252-need-more-internal-usb-headers/
You could get an expansion card, a usb3.0 to 2.0 adapter, or lose corsair link.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Hi guys,
2. Corsair Link
3. NZXT Kraken x61
Thank You
Honestly, skip out on Corsair Link, and CAM Software.
CAM software is only useful to change the LED color of your AIO, other than that, its junk.
Same with Corsair Link, not necessary.
Just control your fans off of your motherboard using Fan Xpert.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
I like to see how much power my pc is consuming, not for a particular reson but I like all the bells and whistles
And also I really like the CAM software.
Your opinion is very good. It is just that my requirements are little different. Thank you
HWiNFO will give you all of the information you need, and it doesn't use up your CPU like CAM.
CAM software sometimes uses up 20% of an i5.  That is INSANE for a simple monitoring program.
What's unique about CAM software I've never heard of this one before.
I didnt know it was so CAM was so much CPU intensive. I will give HWiNFO a try for sure.
I don't think anything is truly "unique" about CAM, other than being able to change the LED color on your X41/61.  Anything it offers is already available from a less demanding program such as HWiNFO.
For example, if you wanted to change fan speed through CAM, it has a long delay before it actually takes effect.  Unlike with Fan Xpert, which is instantaneous, and doesn't use up to 20% of your CPU.
