Nvidia Surround issues
Go to solution Solved by johnmhigh,
Turns out that having frame locks and VSync on causes this in some games, once i turned them off it was fine, only in FIFA i do get some screen tearing because its running at like 300 FPS. also running it on windowed mode did the trick too.
hi, so ive got a 5760 x 1080 surround set up going but on some games, fifia 14, assetto corsa, i get strange half black screens on two monitors that appear then slowly decrease to the bottom and disappear then it will do it again, but battlefield 4, skyrim, crysis 3 all work fine.
i am however using 3 different monitors, on the left i have a "neon" 22" connected by HDMI to DVI via adaptor, centre is a Benq 24" connected my HDMI and on the right is a 22" Samsung connected by DVI all on a GTX 780
at first i thought this would be the problam but other games work fine.
Also F1 2013 wont even launch from steam.
Thanks in advance.
post-129393-0-36087100-1413170997_thumb.
https://linustechtips.com/topic/232186-nvidia-surround-issues/
Try updating drivers.
Perhaps it is just a issue with the game?
https://linustechtips.com/topic/232186-nvidia-surround-issues/#findComment-3174028
all drivers are up to date, lots of vids on youtube with the same games working in surround so it shouldnt be an issue there, im thinking it could be because the monitors are different sizes and makes, but then why do other games work??
just dont wanna buy two more Benq's and have the same issues
https://linustechtips.com/topic/232186-nvidia-surround-issues/#findComment-3174065
it could be that i had that problem too but reinstalling drivers fixed it
My Main Build: NZXT S340 - NZXT Kraken X31 - Crucial MX100 256GB - i5 4460 - Gigabyte Z97P D3 - Kingston HyperX Red 8GB - MSI Nvidia GTX 780 3GB - Corsair LL & HD RGB Fans, Corsair Lighting Node Pro.
https://linustechtips.com/topic/232186-nvidia-surround-issues/#findComment-3175190
  • 1 month later...
https://linustechtips.com/topic/232186-nvidia-surround-issues/#findComment-3526561
