Water Cooling Loop Help
Go to solution Solved by Shaqo_Wyn,
Dual 240's is not overkill. :)
Good parts, the Alphacool Apogee XL blocks is supposed to be cheaper (unless you were planning of utilizing the 4 port feature of the HD).
Personally I'd put a 280 UT60 in the front but maybe that won't work if you need your drive cages. Also bay reservoirs can be a pain to bleed/drain.
What components are you cooling? What exactly do you need help with in terms of setup?
Loop order doesn't matter too much, you just need res above pump. A good loop order for clean tubing runs would be: res > pump > GPU > CPU > top rad > front rad > res.
https://linustechtips.com/topic/231792-water-cooling-loop-help/
Decent setup but abit overkill but atleast you will get good temps with some low rpm fans.
WC is expensive, usally the most exspensive part is the fittings.
I know it's overkill.
But I plan on a really quiet loop, or maybe adding a GPU block at some point later.
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/231792-water-cooling-loop-help/#findComment-3168971
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/231792-water-cooling-loop-help/#findComment-3174705
