Android bluetooth connection
Thanks for your reply. And yes that was my idea aswell but you have to work with input and output streams. And the only thing i know that is usefull for is for sending files or stuff like that.So no idea how i should send some kind of a signal via that.
I've worked with Tcp/Udp but I'm not familiar with bluetooth. I can't say for sure but if you can transfer files, which is basically just an array of bytes, there's no reason to think you can't transfer your own byte/byte array.
You might only need a single byte to represent a command
commandByte = 1; // Represents command 1 (An Enum or something can be used to define the commands in a readable way)
Or if you need to transfer more information along with it, maybe a byte array like this would be better
commandByteArray[0] //could identify a commandcommandByteArray[1 to 4] //could be an integer (4 bytes) representing the length of total bytes needed to be readcommandByteArray[5 to 8] // could be an integer representing the ID of the sending device/usercommandByteArray[9+] //could be any additional data (if needed)
Unfortunately I can't really provide any help in how to use the streams to send/receive this info but if you can do it with files, I'm sure you can get it done with your own data.
