Afternoon!
I'm veryyyyy new here but I have a question,
Im new to the whole custom built PC's after using a Mac the last 4-5 years,
I bought a new custom build with a GTX760 and I have a 37inch HDTV,
I'm wondering if I can use the TV as a monitor,
I haven't received my PC yet that's why i cant test,
I'm just curious!
Thanks in advance!
Rory.
https://linustechtips.com/topic/230589-display-help/
yes you can, all you need is a hdmi cable
CPU Intel I7-4700MQ @2.4 ghz, turbos to 3.4
Motherboard  whatever toshiba put in the thing
RAM 8GB 1600mhz
GPU  Nvidia Geforce GT 740M
Storage 750Gb 5400rpm
Cooling  Crappy laptop fan
Operating System  windows 8 64 bit
01101001 01100110 00100000 01111001 01101111 01110101 00100000 01101000 01100001 01100100 00100000 01110100 01101111 00100000 01000111 01101111 01101111 01100111 01101100 01100101 00100000 01110100 01101000 01101001 01110011 00100000 01101001 00100000 01100100 01101111 01101110 00100111 01110100 00100000 01100010 01101100 01100001 01101101 01100101 00100000 01111001 01101111 01110101
https://linustechtips.com/topic/230589-display-help/#findComment-3155402
Will be be the right res? my iMac has trouble using the TV as a external display, underscanning,not sharp etc...
it will be right res, but to be honest with you dont do it! even a cheap 1080p monitor is usually more appropriate for using a pc than a tv screen. Sometimes the edges of the screen are being cut of by the tv because of weired scaling and the response times suck.
If you use it anyways though try to find a setting in the tv that is called something like game mode. It switches off colour correction which is needed for tv signals and reduces response times which is good! but yeah really save yourself some money and buy a pc panel...
https://linustechtips.com/topic/230589-display-help/#findComment-3155894
