starting with visual basic
Solved by madknight3,
It looks like your button events are unfinished. Incorrect parameters and no event handle
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click ' Code hereEnd Sub
In the designer, you should just be able to double click on the button which is a shortcut for the click event method in code.
